1ls 6.5" Speakers all-around?
I am aware that the stock speakers in the 1ls are 4.5" speakers, but has anyone modified their boxes to sit 6.5" speakers all around (front and rear)?
I know 6.5" speakers can push much more air so that's why I was wondering if anyone has done this upgrade.
Discuss!
-Alex
Discuss!
-Alex
heres a tutorial for a 5.25 speaker, Id imagine the process would be the same just harder to do for a bigger speaker...
http://www.lexls.com/tutorials/audio/fspeaker.html
Most likely easier to make a new baffle for the speakers if you plan on running 6.5" speakers. I modified mine to 5.25" with a dremel tool, took awhile and was a slow process, but the speakers fit but you will have to reinforce the one edge b/c it WILL crack once you screw them in.
Yes it is a very easy job to open up stock speaker mounts I have done 1st gen LS and 2nd gen LS.Plus the rears too.
https://www.clublexus.com/forums/sho...t=6.5+speakers
I don't remember where they are , the 1st gen belong to persian451 you could try a search , I don't keep many pics on my computer and dump them after I use them , sorry...But if you are a SoCal guy I could help you out at my garage ( shop ) .
Unfortunately I'm on the other coastline, lol.
I'll try a search.
For the 1LS ones, did you simply just dremel the enclosure into a bigger hole without tampering with the backside?
How did you mount the speaker into the hole after that, just screw it in?
I'll try a search.
Yeah I just put 6.5 JL Evolution components in my 1ls. The key is spacing. After cutting the hole I bored out a .5" spacer, and mounted the speaker to the factory housing. The key is to not screw the back part of the housing back on. All in all it took me about 3 hours, then again I'm an installer lol. But good luck and take your time!!
engin_ear
07-31-20 05:11 PM
