Engine stalls after prolong Freeway driving
Old 04-19-07, 02:51 PM
Berez Haim
Berez Haim's Avatar
Can you please find out the TSB number
Old 04-19-07, 02:55 PM
hlippy4
hlippy4's Avatar
Default I posted it earlier............
I'll see if my dealer has a copy of the actual TSB -- I'm trying to help because this is a little known TSB that someone here gave me after a week of attempting to find out what was happening with my car......saved me big $$$$$$$$$$ -- it was specific and direct
Old 04-19-07, 03:25 PM
hlippy4
hlippy4's Avatar
Smile hope this is helpful to all....engine stalling.....here goes
brief synopsis..........hidden TSB eg002-97 (at least I remember and it seems to be true that almost no one knows about and almost impossible to find -- my dealer claimed they never saw or heard of it)...........dated Feb 28, 1997............has to do with idle turning off and car stalling "after continuous high speed driving"....as read directly to me today by my guy at Lexus..........ECM logic has been changed........new part number 89661-50303..............good luck --
Old 04-19-07, 03:59 PM
eagle33
eagle33's Avatar
Thumbs up Check this out
Thats right, but only for 96 model. 96 has 89661-50302 original ECM and needs 89661-50303 upgrade. Check this old tread below:
"I am trying to make a thread here for the many of those with low idle, engine quits after an extended highway cruise when coming to a stop, and a mysterious drivetrain jerk when you let off the throttle and get back on....sometimes...and usually happening over 40 mph.
My 95 Ls400 built april of 95 which now has 150,000 miles has these problems.
I've done full diagnostics. I've gone after the throttle body and the Idle control valve. All of which were working perfectly. After 3 days of reading threads at several different forums of similar problems with 95's, several emails and follow ups on who found what the problem was and how solved I wanted to put all the information here so the next guy could find it easier.
Some guys are driving around with the a/c on to keep the engine running at a faster idle to keep the car from dying.
I'm convinced all 3 problems are related to the ECM and it's controlling of the idle air control. While there were a couple of TSB's on this it was never a recall. Those of us who bought used or have high miles are out of luck for any dealer help...at least I would think.
Your Ecm is located behind the glovebox on the passenger side. If you want to read what number Ecm you have..you can do that by not removing it. Just remove the lower plastic panel below the glovebox and look up in there. You'll see "Engine Computer Label" and the numbers.
For 1995's:
Your original Ecm is either:
89661-50220 or 89661-50221 if Federal (49 state). Lexus new replacement on the TSB says to replace with 89661-50224
If California then your orginal Ecm is either 89661-50230 or 89661-50231. The TSB calls for 89661-50234
But searching a local Lexus parts site shows that number has been replaced with 89661-50235-85.
The cost of these Ecm's new is just total crazy. But there might be another solution.
One member bought a used pcm from a wrecking yard #80661-50224. He paid about $150 for it and it solved his issues. I did some searching in wrecking yards and there are some of these #'s out there.
If you have a California car then there seems to be few out there. Mine is a California car. I don't know if a 49 state Ecm will work...I suspect it will...but unknown at this time.
Another member bought a remanufactured Ecm for his 49 state car. He paid $300. for it and it has a 1 year warranty. He also stated that it cured all problems. The company he purchased it from was Auto & Truck Electronics in West Palm beach, Florida. He said the part number was #95 Int 56834. (That was a 49 state unit).
There are other places on the web where rebuilt Ecu's are sold. The problem is most are listed by the old number. We have no way of knowing if the old units are rebuilt and then "reflashed" to the later specs which we are looking for to solve these issues.
I'll try to find out about that and post here what I find out.
For 1996's: The Ecm you want is 89661-50303. Original's were 89661-50302. A wrecking yard buddy did a nationwide search and there are used 89661-50303's out there. Evidently these work in all 50 state cars.
Ps: A 1996 Ecm will not work in a 95. It turns the check engine light on. That's been tried.
Update: I just received an email from the gentleman who bought the remanufactured pcm from Auto & Truck Electronics(mentioned above). He confirmed with them that the Ecu had the latest software upgrade before he bought the Ecu. He also commented the car shifted smoother than it ever did."
Old 06-24-07, 01:12 PM
tantheman
tantheman's Avatar
I'm interested in the ecm you posted for the 95-96 ls.Let me know if you still have it?
Thanks,
Wayne Tanner
Old 06-24-07, 01:24 PM
hobojoe
hobojoe's Avatar
boy am i glad i dont have that problem 1rst gen all the way lol!
beavis
04-30-17 02:08 PM
BigBang
SC- 1st Gen (1992-2000)
08-07-11 11:02 PM
firewire
17
01-26-10 12:21 AM
rcltrh
17
10-17-02 01:15 PM
Quick Reply: Engine stalls after prolong Freeway driving
