Steering problem on '91 LS400 after pump was replaced...
I just had the p/s pump and hoses replaced as well as the solenoid cleaned.
I only notice a minute difference in the steering. The leak is still there, which is probably the idle air control valve.
Jeez, the steering was tight and I had a leak, $800 later, the steering is pretty much the same and the leak is still there.
Any suggestions?
I've had the car for a few months, it looks like there was definitely some front end damage, not sure if that's the culprit.
I'm sure everybody's gonna say, get new air control valve and new rack.
I've tried out a few older Lexus's and the steering is incredible, loose just the way I like it. No resistance. That's what I want. My steering is tighter than I like. I can live with it, but it definitely takes away from the ease you should have driving a Lexus.
Is it possible that I get a new rack and my steering is STILL tight??
Any suggestions?
Hey wasnt trying to get on ya,, just trying to help you save a little money, especially since dealerships charge soo much. Most of the time, doing an advanced search will net results in which your concern has been addressed many time before. And, as much as I hate to say it(LOL!!),, Pure Drifter is very knowledgeable about what is going on with our cars and in many cases he can steer you in the right direction as well. He can be very blunt sometimes, but take heed to some of the advice given here on the forums as well.
I asked a question and instead of helping, you just say "do some research". Well, that kind of goes without saying. This forum is apart of my research.
I agree with that,, lots of people here will ask without doing any research at all. I did come off wrong and I apologize. IMO changing the Idle air valve should eliminate your problem since you have already addressed everything else.
Yeah, I came off wrong as well. I should have definitely changed the air control valve first. I'm sure that's what you meant by research. It's just frustrating when you spend a lot of money and don't get results.
I know changing the air control valve will solve my leak, will it help solve the tight steering problem? I really want to avoid having the rack done. I can't really afford it right now anyway.
Any help is greatly appreciated. thanks guys.
Are there any electronic controls in the steering system that could be a culprit. I know on the Q45 I had there was a sensor that when it was going bad would give tight steering and then loose steering out of no where.
How about checking all pressure lines? Do you have any apparent leaks coming from the rack itself? Are the boots on the ends busted?
I think you might have used steering fluid instead of the dexron III/Mercon ATF.
I made that mistake and what's happening to you, happened to me 3 weeks ago. The steering was hard as hell and it also jacked up my p/s pump. I sucked out the p/s fluid and put in the right stuff and it took the hardness away, but my pump was jacked. I still managed to drive the car on a 900 mile trip and had no problems other than the pump making noise.
I replaced the pump and problem solved.
Good luck!
Good luck!
Good luck!
Good luck!
Thanks for the information, much appreciated.
theschoens
48
10-28-18 05:29 PM
jdub20tx
Performance & Maintenance
08-08-12 06:29 PM
91LS400LEX
13
01-04-10 07:22 PM
djr73999
02-01-06 01:37 PM
