One small klick begins disaster for engine
Old 05-05-07, 10:21 AM
swiggins
swiggins's Avatar
Default One small klick begins disaster for engine
Hi all.
Had a shim slip out of one #4 cylinder exhaust valve. It got hung up with the valve stem and locked the valve open. This ruined the head. It turns out that
head work is so expensive that for my '91 with 150000 miles on it's better to replace the engine with a salvaged one. I got a 50000 engine for $1250 and it will be about $1500 to install. Don't do like I did and wait for a better time to stop the clicking.
Sad and Broke
Sam
Old 05-05-07, 03:06 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
u can get 1uz motors for <800 out here in CA.......
labor sounds a bit much too, shouldnt be over 1200.
Old 05-05-07, 07:35 PM
SW07ES
SW07ES's Avatar
Did your engine have a "klick,Klick,Klick" type noise at idle before this happened? Is so, it sounds like the exhaust valve clearance on cylinder #4 was wildly loose and provided enough clearance for the valve adjusting shim to slip out.
Do you mind telling us how you were driving when the shim slipped out? In other words, was the engine spinning slow or at high rpm? decelerating? etc. Thanks
Old 05-06-07, 08:08 AM
swiggins
swiggins's Avatar
I had just changed the oil and was starting the engine to back down off the ramps. Happened as I turned the key.
Sam
Old 05-06-07, 08:18 AM
swiggins
swiggins's Avatar
Puredrifter, my usual repair shop wouldn't touch this job. I'm trying a new guy and I hope every thing works out. I found engines from $500 to $2500 around the southeast on www.car-parts.com. This one comes with 12 months warrenty so I took the middle ground. There are not many choices for Lexus repair around
here so they can get premium prices.
Sam
tn96dc
10-30-13 02:41 PM
chi123
06-02-13 09:17 AM
DosyBoy
06-28-12 12:14 AM
SC300_704
Performance & Maintenance
11-01-11 08:41 AM
Monkiee
08-16-09 02:20 PM
Quick Reply: One small klick begins disaster for engine
