Just got my repaired LCD back...
Yup, I bought mine here.
http://www.superbrightleds.com/cgi-b....24493&next=50
Be wary though. It feels like the LED wont fit. And it won't not without shaving the sides a little or forcing it in there like pulling teeth.
The circumference of the bulb holder is slightly smaller than the LED plastic replacement piece. It needs a little elbow grease and/or delicate "shaving" with a razor" to go in place.
Good to know, thanks!
![Smile](https://www.clublexus.com/forums/images/icons/icon7.gif)
You have to unscrew all four screws of the actual shifter cover (the black part) and very carefully twist it loose. There is also a factory wire tie (which you made need to cut) to get more maneuverability.
I don't take any credit, props really go to http://www.lexls.com for setting me on the right path for coolness.
since you are talking about the shifter area, may be you can help me about the loose shifter : shifter moves slightly to the left or right. The whole shifter feel like falling apart at P. Seems to me underneath the black cover, there must be something (bushing?) to station the shifter. Do you have any idea what is missing or broken to cause the shifter to move slightly to the left or right? Thank you.
Hi avalon42,
https://www.clublexus.com/forums/sho...d.php?t=300599
As for your question, when you say the shifter, are you talking about the **** itself, or the shaft that is moving left to right? Have you taken the cover off and examined the area yet?
![Thumb Down](https://www.clublexus.com/forums/images/smilies/thumbsdown.gif)
Well, it depends, because I already answered you on this thread.
kayuwong
07-22-10 06:40 PM
