Rim Compatability
Old 05-25-07, 11:10 AM
flamekat
flamekat's Avatar
Default Rim Compatability
Can somebody please tell me the largest size rim/tire that can fit on a 1998 ls 400? My brother has an set off his new S550 Merecedes and I need to know if they will fit on my car.
Old 05-25-07, 11:16 AM
Suneet
Suneet's Avatar
Don't the Mercedes have a different bold pattern all together? I thought they had a 4x something pattern where are cars are 5 x 114
Old 05-25-07, 11:45 AM
Blavatsky
Blavatsky's Avatar
try to find out the size, width, offset, rim bore, and bolt pattern. If all that is compatible, then you just have to worry about clearing your brake kit, which I've heard can be troublesome.
Old 05-25-07, 11:47 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
mercedes run a 5x120 PCD (bolt pattern) vs. Lexus/Toyota's 5x114.3 so these wheels wont even fit on the hubs. Redrilling MAY be possible but if done incorrectly compromises the integrity of the wheel structure.
Old 05-25-07, 12:51 PM
steveski
steveski's Avatar
Too bad they won't fit - the Benz rims are nice looking - and maybe free!
Old 05-26-07, 06:01 PM
turbosix
turbosix's Avatar
you need something like this...
Old 05-26-07, 11:40 PM
RA40
Super Moderator
RA40's Avatar
MB is 5x112 and the Lexus is 5x114.
Rather than risking a re-drill, the easier way are wheel adapters to convert the 5x114 to 5x112. This way you can have your MB wheels and not make them a difficult sell since they were not re-drilled.
Old 05-26-07, 11:57 PM
PureDrifter
BahHumBug
the only problem with wheel adapters is that they act as spacers and lower the offset ~20-30mm. (sticks out 2-3cm+)
Old 06-01-07, 07:24 PM
respond2
respond2's Avatar
Since were on the topic of fitment. Is it true that all Lexus OEM wheels fit on all of the models but the Ls460?
Old 06-01-07, 08:46 PM
RA40
Super Moderator
RA40's Avatar
The exceptions are the second gen+ LS's which have the larger 4 piston calipers. I'm not sure of the new '07 GS...?
Old 06-01-07, 09:47 PM
PureDrifter
BahHumBug
all pre 01 cars can interchange wheels EXCEPT the 95+LS400 which can ONLY use Supra TT or its original wheels.
new LS460 will not fit ANY previous Lexus or Toyota wheel as the PCD (bolt pattern) changed from 5x114.3 to 5x120
So Philly1
11-26-08 12:31 PM
xposure
11-12-08 07:56 PM
SCchick
Wheels, Tires & Brakes Forum
03-23-06 07:27 AM
RUDENESS
09-28-04 01:05 PM
Quick Reply: Rim Compatability
