Easiest way to drill out rotor set screws?
Old 05-26-07, 03:27 PM
LS400_Fan
LS400_Fan's Avatar
Default Easiest way to drill out rotor set screws?
Went to change my front brakes today, 96LS with 104,000 on it and the set screws are already stripped from the last time brakes were done.
I'm sure this is a common problem and figured one of you would know the easiest way to drill them out and with what size bit.
Thanks for your help.
Old 05-26-07, 03:40 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
go to sears and ask for a screw-out system.
or take an appropriately sized chisel, hammer it in, and try to turn the screw that way.
drilling it out may damage the rotor and will most likely damage the hub.
Old 05-26-07, 04:32 PM
LS400_Fan
LS400_Fan's Avatar
I have new rotors so that isn't a problem. It shouldn't damage the hub as long as the bit isn't too big.
I'll try the sears route first.
Old 05-26-07, 09:02 PM
Lexiss_sc430
Lexiss_sc430's Avatar
get a drill bit that is about half as big as the screw itself, and just drill it out.... that sucker will come right out...
I’ve done it soo many times before.
if your confident enough to do this job and competent enough to use a drill would wont damage a thing... its a pretty easy job
Old 05-27-07, 10:38 AM
19psi
19psi's Avatar
the screw is actually made of pretty soft metal so it will drill out very easily.
Old 05-27-07, 12:45 PM
CK6Speed
CK6Speed's Avatar
After you get it removed invest in an Impact Driver. This is a tool that looks like a fat screwdriver but you hit the end with hammer. What this does is slowly back out any stuck screw without stripping the head until it breaks free. I NEVER attempt to remove those rotor set screws with a screwdriver unless I know it will back out. I always use the Impact Driver first if I'm in doubt. Never had a stripped screw yet. The saying "The right tool for the job" is so true.
Old 05-27-07, 02:30 PM
skperformance
skperformance's Avatar
The best preventive measure is anti seize used on the head and threads otherwise they do bend and strip.
Old 05-27-07, 04:27 PM
LS400_Fan
LS400_Fan's Avatar
Well the impact driver would be great, however when i took off the wheels they were already stripped
My solution once i get them off? Just not going to put them back on LOL. The wheel is going to hold the rotor in place anyway, so these really aren't needed imo.
Old 05-27-07, 05:36 PM
avalon42
avalon42's Avatar
Idiots. I would beat the person that stripped my screws.
Are you sure there isn't a remote chance of play if the screws are not used?
Old 05-27-07, 06:40 PM
skperformance
Buy new screws and replace them .
the brakes are quite strong and will cause the rotor to float on the hub impacting the studs and making banging or clicking noises when changing directions.
MarksES300
08-10-17 01:20 PM
wald.sc400
Suspension and Brakes
14
05-19-11 08:44 PM
kanukem
SC- 1st Gen (1992-2000)
06-02-10 11:46 AM
vwynn
05-01-08 01:04 PM
seanl
03-07-04 05:05 PM
Quick Reply: Easiest way to drill out rotor set screws?
