Coil Over Compatibility
Im curious on what people know about the compatibility of coil overs on the LS , I have owned SC/SUPRA and a GS and understand their compatibility but never thought to ask about the wifes LS.
This would be on a first gen LS
Many coilovers will fit the LS, as long as the bottom of the strut bolts up and the top mount matches. For example, you can use Q45 fronts and GS fronts and they will work fine. I've seen one guy put R32 sedan rears on his rears.
Just keep in mind the weight of the car the coilovers are coming off of.
I understand spring rates and valving, I use allot of coilovers and can change spring rates. I was just curious on what models interchange. I saw a LS that had advertised MK3 supra suspension before and it got my wheels turning.![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
Also what coilovers are available for the LS?
CAnima
16
04-28-15 03:46 PM
6deep.com
08-19-03 11:47 PM
coilover, coilovers, compatability, compatibility, compatible, fit, lexus, ls400, mk3, supra, toyota
