integration relay
integration relay
having problems with my interior dome light not working in the DOOR position. works in the ON position and the door on/off button works fine. did a search, and read up on the problem being the integration relay. it said its above the interior fuse box, but thats about it. maybe someone knows if it has a number on it, or its positioning...
i was hooking up my puddle lights to the under dash lights so it would fade out turning off, and the wires must have touched and burnt something out. all help is appreciated...
damn, totally forgot to mention that 94 ls400. checked ALL fuses, under dash, and under hood, good. searched here and another lexus forum, and all arrows point to this relay. my dome light works in the ON position but not in the DOOR position. the lights on the front door panels work fine, ON when the door is open, off when closed. i checked ebay, and apparently the relays are labeled. i just dont want to be looking in the wrong place. im tearing things apart as we speak, just gotta drop the interior fuse box to see if it is there....
searched more, this relay is supposedly behind the fuse panel, checked for myself (what i could see before i take it apart) and there are alot of relays plugged behind the fuse panel. i suspect its there. for a SC its to the left of the steering column. so i think im getting close. its about 1145pm so i will have to hold off till morning...
