cleaning throttle body
I did mine the lazy way. I took off the intake hose and sprayed carb cleaner inside with the throttle opened, then cleaned it out with a cloth/rag. Just kept spraying and wiping around untill it seemed clean. The car ran better.
I am assuming that you must spray the seafoam.
If you still wanna give seafoam a shot, here's what you do. Start your car, bring it to the operating temperature. Then have your friend keep the throttle at around 2000RPMs to keep the car from stalling, remove the PCV hose, and let it slowly suck in about half a cup of seafoam. Dont put the hose directly into the can, better off pour it in a cup, and then hold the hose about 1/2" above the fluid so it slowly sips it in. If you let it suck it in fast, you're risking hydrolocking your engine. By the way, don't use a plastic cup, seafoam might dissolve it.
Once all the fluid is sucked in, shut the engine off, and let it sit for 10-15 minutes. The start it back up, and drive it hard until it stops smocking. Then pour the remaining half can into your oil, and after you drive 100 miles on the oil, change it.
You don't use seafoam to clean throttle body. Seafoam claims to clean the entire intake manifold, including the throttle body when you suck it in throught the brake booster or PCV hose, but in all honesty it doesn't do jack. I could see it being effective when used in crankcase, but intake manifold, no way. When I removed my throttle body, I couldn't clean all the build up by directly spraying carb cleaner, I had to scrape it off with screwdriver. So just remove your throttle body and give it good cleaning.
I dunno about that man. Maybe becuase my car was just in such bad shape, but when I used seafoam through my PCV valve, I noticed an immediate and huge change in response, and speed.
I then did a TB cleaning by hand, and that helped quite a bit too. The final kicker was getting all my spark plugs and wires replaced, along with caps, rotors, and both ignition coils.. and the car rides better than ever.
![](http://www.lexls.com/images/pcv/pcv1.jpg)
That is where your PCV hose plugs into. Use that, its the easiest.
Pic taken from a LexLS tutorial.
http://www.lexls.com/tutorials/emission/pcv_valve.html
Man, if that site ever goes down... I dunno what I'll do!
Um, I would be careful following the Lexls tutorial on cleaning the intake with a flat screwdriver. Getting any carbon deposits and/or aluminum shavings into the combustion chamber would be like running your car without an air filter through the desert on a windy day. You can possibly damage your piston rings. No thanks.
Comments? Could I be wrong about this?????
![](http://www.lexls.com/images/tb/tb10.jpg)
also, your sandy day analogy is inaccurate, the black carbon in the intake manifold will burn off completely inside the combustion chamber (and any tiny tiny shavings of aluminum wont hurt anything), unlike sand, which wont burn in the combustion chamber and in adequate quantity will likely scrape up the cylinder liner a fair amount, causing blow-by.
Oh, and when i did the TB cleaning on my '95 LS, the car ran perfectly until it was killed
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
and steel wool (of a relatively fine grade, or a scrubbing/green pad) works as well as a screwdriver when u soak both the throttle butterfly and the sponge/pad in TB cleaner
Step 11 of the tutorial:
Clean up the air intake chamber as much as you can. I scraped off as much as I could and then used the STP cleaner. When it was clean I replaced the throttle body gasket (part # 22271-50010) with a new one.
I believed I referred to the intake also, not the TB.
Thanks for clearing up that tiny particles of aluminum will NOT hurt my engine
DarwinX
RX - 1st Gen (1999-2003)
26
05-05-10 09:34 AM
