Air Suspension Failure
'90 LS400 266k milies
$2,500 and counting... Since last fall, I've replaced the following air suspension components. Obviously, I would have installed coilovers if I had known want I was getting into earlier.
- New OEM Rear Air Strut
- Rebuilt Rear Air Strut
- Rear air suspension pump (used)
Has worked OK since. This weekend, the entire car dropped.
Assuming that 4 struts and 2 pumps did not fail simo, what would cause the entire system (front and rear) to fail simultaneously? I've reset the control module but the car won't raise.
Chip L
Chip L
