really dumb question about AC
ok, so i went out and bought the r12 to r134a converter and had someone start charging it. come to find out, the compressor is broken. apparently, the previous owner tried messing with it, so now it doesn't work.
just thought i'd update...
Even if you have a '90-'92 there is no need to convert since R12 is cheap and plentiful on ebay and so are the R12 can tap valves and charging hoses.
Your local dealer and AC shops won't tell you this because they'd lose business if they did.
The system was completely empty (no pressure or anything). I noticed that when I was replacing the service valves that the high pressure end was completely loose! So replaced the valves and I just put in 3 cans of R12 and some oil to recharge my system today. AC is blowing a smooth 58 degrees Fahrenheit (tested).
