new ride height! what do you think?
#31
#33
#34
#36
#38
#39
u comin to the 7.22.07 bbq in LB?
#41
[QUOTE=PureDrifter;2758464]no, im talking about STROKE length. this cant be compensated by damper/spring tuning.
im not talking about dampering and spring turning, since the preload is set the stroke travel would be the same, only the height is adjusted by the lowered bracket thing, the the height is differnt, but the stroke stays the same. i duuno if im saying this right, but heres a picture
if its like this
the lower you go, the shorter the travel of the shock, since its not a preload, and height adjustable coilover
on the other hand,
if its like this
the springs stays at 0 preload maintaining stroke travel, while the height and the length is adjusted through the bottom bracket
i think as long as the threaded shock body has enough height adjusments, it can possibly work on both 1ls and 2ls
not promoting anything just borrowing pictures haha
if its like this
on the other hand,
if its like this
#42
im talking about the PISTON stroke, not the overall stroke.
piston stroke is limited by length of the piston itself. so theoretically i guess u could have a machine shop cut part of the piston off a 2LS coilover and put it on ur 1LS....
#43
At one finger wheel gap, the car rides like stock, just a tad firmer. At the ride height I'm currently at, I bottom out on sudden bumps. I think I could fix this if I add more preload on the springs and adjust the damper.
Driving at this height is just crazy, I already blew out two tires due to alignment wear and cracked one of my exhaust pipes. I'm raising the car an inch so I can get this thing on the alignment rack.
#44
