Interior Lights 98-00 LS
BahHumBug
pry with a plastic putty knife, screwdrivers leave gouges, i know this personally
most bulbs are 194, there are like 4 BA9 bulbs for the maps on the front and above the rear doors, i recco a pair of pliers and to close the door when taking them out since the bulbs get hot QUICK.
BNastee (01-03-24)
I recommend wrapping the pliers in electric tape too. protect the bulb.
I use a mini screwdriver from snap on and pop off one side at a time as every side has 2 clips and it is a pain to get off.
I replaced all my interior lights with LED's All the bulbs are 194 except the key cylinder and foot well uses a small little bulb , i replaced mine with a varad interior led by wiring it directly . I also use 2 led dome lights tystrapped together to double the output as i had a 9 led festoon bulb but it was from hong Kong and kept having bulbs dieing. So i used the 2 together with one in the clips and the other one pressed against the contacts to light it as well.
I made a thread a while ago with pics.
Thanks for the replies. I havent bought them yet because this is KEntucky and finding a parts store that sells anything besides OEM and absolutally rediculous to find, and when you do find it...it's costly. Autozone carries 2 194 bulbs that are blue for $15 each. Thats about $75 in just THOSE bulbs... it would cost near $150 bucks to replace all the lights in the ride...is it worth it?
Anyone have ideas besides ebay...or ebay luck?
BahHumBug
www.superbrightleds.com
i use the 1st place for all my LEDs
BahHumBug
for 2LS (95-00)
2 x #74 for footwells
1 x #74 for ignition cylinder (led will need some sanding to fit right)
1 x #74 for glovebox
4 x 194 for doorlights
4 x 194 for rear maplights(on C pillar)+rear door dome lights
2 x 194 for front corner markers
2 x 194 for rear license plate lights
1 x 194 for trunk interior light (do the neon conversion, MUCH better light output than any 194 bulb or LED)
2 x BA9 for front maplights
2 x BA9 for rear maplights
1 x 31mm dome light
hmm, i think that now that i made this il go add it into the UCF20/21 FAQ
1 x 31mm dome light
There is 6 194 for the rear map reading lights.
I agree with a neon as the bulb is badly positioned and cannot be seen. I would mount a neon under teh trunk lid so it shines down as anything high in the trunk in the stock position gets blocked easily..
for 2LS (95-00)
1 x 31mm dome light
1 x 31mm dome light
kidoekid
02-10-09 11:01 PM
