Replaced lower ball joint on 1LS...great results
Some of you recall I had a front passenger's side "thud/clunk" sound when going over irregular surfaces/bumps. Most suggested it to be the lower ball joint. The other most common alternatives are upper control arm bushes/ball joint, or strut rod bushing.
Well, the lower ball joint is the cheapest and easiest to change out, and makes the most sense for the vertical motion-triggered thud sound, since it wasn't making the noise in braking conditions (fore/aft movement).
I replaced the lower ball joint for less than $60 from olympus parts using the procedure from this thread:
https://www.clublexus.com/forums/sho...d.php?t=153536
Less than an hour, and back on the road. No thuds...the diagnosis on this one was right on. BTW, car is a 1990 with 85k on the odo.
Thanks to the great wisdom and experience on this board.
When I replaced my lower balljoints at 185K, I didn't notice a huge difference. BUt I did it at the same time as my Daizen CA bushings, and it tightened up the steering quite a bit.
I still have a clunk when going over small bumps at slow speeds.. so maybe my culprit is the strut rod bushing?
