Tire wear on the outside edges?
Old 07-11-07, 02:22 PM
jlp93
jlp93's Avatar
Default Tire wear on the outside edges?
I am seeing excessive tread wear on the outside edges of my tires, especially the fronts.
Is this most likely an alignment issue or a worn suspension issue?
Thoughts? TIA
Old 07-11-07, 02:47 PM
LiCelsior
Retired
LiCelsior's Avatar
camber issue?
Old 07-11-07, 02:51 PM
etex
etex's Avatar
Good sign of probable under-inflation, also.
Old 07-11-07, 06:09 PM
4theboys
4theboys's Avatar
Default Tire Wear
Had similiar issue and ended up being the toe.....
Go get it aligned before you have to replace the tires like I did.
Good Luck.
Old 07-11-07, 06:32 PM
JDMCelsior
JDMCelsior's Avatar
Good God someone asked, I was wondering the same thing. I thought it was + camber, but normally that shouldn't be the case unless other suspension part is worn. I think?
Old 07-11-07, 11:21 PM
tuterz
tuterz's Avatar
wow.. i have that same issue.. but i thought because it was the bigger wheels.. and.. when i turn.. the.. wheels lean.. and.. the outer edge of my tire rubs the ground... or is that another issue?... =/
Old 07-11-07, 11:34 PM
jasonm
jasonm's Avatar
If it were the suspension, the car would sag and have camber that would wear the inside not outside.
Old 07-12-07, 02:31 AM
CK6Speed
CK6Speed's Avatar
If both the inner and outer are wearing out I would suggest under inflation of the tires. If just the outer tires are wearing out especially the front I would suggest toe. Too much toe in will cause this. You need an alignment.
Old 07-12-07, 05:48 AM
TJW98LS
TJW98LS's Avatar
Camber issue, Wheels are too big, under-inflation, or your alignment is wrong. I think all of that has been stated already
Old 07-12-07, 11:41 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
camber issues on teh LS cause inner tire wear, toe causes outer.
Old 07-12-07, 01:56 PM
mobilyte
mobilyte's Avatar
i had r&r'd my steering rack and didnt get a chance to get an alignment right away. both front wheels had inner wear after a while because of the toe adjustment.
Old 07-12-07, 05:15 PM
CK6Speed
CK6Speed's Avatar
Believe it or not, misaligned toe causes more inner or outer tire wear than camber. If I could only get one or the other alignment spec sorted out, I would opt to correct the toe over camber.
Old 07-13-07, 07:13 PM
stuching
stuching's Avatar
Most likely positive camber. If it's toe in or out it'll have saw tooth pattern wear. If it's negative camber it'll wear on inside of the tires.
Old 07-16-07, 01:25 AM
tuterz
tuterz's Avatar
how much does an alignment usually run for?
Old 07-16-07, 01:44 AM
PureDrifter
BahHumBug
ranges from $60-100
race alignments can cost $150+ depending on how many settings need to be changed, but id say u should expect to pay round $70
Quick Reply: Tire wear on the outside edges?
