Dashboard is no longer lit - 92 LS400
Old 07-12-07 | 10:56 PM
sd_ls's Avatar
sd_ls
Default Dashboard is no longer lit - 92 LS400
I have a 92 LS400 w/ 156k miles. The issues began two days ago when the "o/d off" began to flash in intervals of 2-seconds (I drive w/ the overdrive on), and the speedometer gauge stopped working properly (it stop moving w/ accordance to the speed). I think the situation just got worse because today as I was on the freeway heading back home from work, the entire dashboard went dark, nothing was lit and the gauges stopped moving. I figured to check the dashboard fuse to see if it was burnt, and it was. So I replaced the burnt fuse w/ a new fuse of equal amperage, which lit the dashboard, but in a matter of seconds went all dark on me. I tried it again, and just ended w/ 2 new fuses being burnt. If anybody can help me w/ fixing this issue I'll definetly appreciated.
Old 07-12-07 | 11:14 PM
PureDrifter's Avatar
PureDrifter
BahHumBug
CL Folding 100000
before anyone else (or myself for that matter) MAJORLY tells you off, go read the 6th sticky at the top of the LS forum ...
Old 07-12-07 | 11:18 PM
LiCelsior's Avatar
LiCelsior
Retired
CL Folding 500000
mainly page 5-6 for most of the info/pics. helped fix mine after i changed those capacitors.
Old 07-13-07 | 09:06 AM
sd_ls's Avatar
sd_ls
Thanks guys.
YODAONE
17
10-24-19 05:04 PM
nervekiler
04-10-10 10:10 AM
lenunn1923
08-21-08 07:33 PM
sd_ls
12-14-07 09:31 PM
jae
11-22-05 12:18 AM
