Last chance before I give up....
Old 08-07-07, 05:39 PM
601LEXTACY
601LEXTACY's Avatar
Default Last chance before I give up....
Well my fellow ls400 brothers. I did the unthinkable. I repainted the car a pearl grey with a ls460 metallic paint, threw some new 20 inch neeper throwbacks on her and then the radiator explodes in mid highway trip. To no avail I bought another for only 175 bucks. Had my mechanic install it and then an hour after picking it up. It over heats again and the oil light comes on. Oil was in it but mechanic said the head gasket was cracking. Ok. So he took it back to his shop and got it ready to sell. He said it would run fine and wouldn't overheat anymore so I thought about keeping it. But once again, the worst occurs. I crunk up the car and its runs horribly. Like its running on four cylinders and its sounds terrible. So I drove it home. Tried hitting the gas to the floor only to see that it was not punching out like it should. What is going on here guys. Whats wrong with my engine. Its a 91 ls 400 with 275k on it and up until this last repair it ran fine. Why is it running like a sentra and not a lexus.
Old 08-07-07, 06:10 PM
michael200
michael200's Avatar
Is the Check Engine Light on?
Old 08-07-07, 06:15 PM
LiCelsior
Retired
LiCelsior's Avatar
try checking ur plugs and wires. those helped when i thought my car was running < 8 cylinders.
Old 08-07-07, 06:17 PM
601LEXTACY
601LEXTACY's Avatar
how do i check the plugs. I dont know what im looking for. and no my check engine light is off.
Old 08-07-07, 06:21 PM
michael200
michael200's Avatar
One of our LS400 (91) had a coil go dead. The car was indeed running on 4 cylinders, but was able to limp home. Put a timing light on the coil wires one at a time with the engine running, and see if the light (coil) is dead. For the passenger side coil, you will have to remove some of the plastic cover pieces to get to that coil wire.
Old 08-07-07, 06:48 PM
601LEXTACY
601LEXTACY's Avatar
ok. i will take it to my regular mechanics and see what they can do for me. are u sure that is what it might be.
Old 08-07-07, 07:11 PM
LiCelsior
Retired
LiCelsior's Avatar
lextacy, www.lexls.com will be ur new best friend.
Old 08-07-07, 07:16 PM
601LEXTACY
601LEXTACY's Avatar
anyone know a price on the ignition coil
Old 08-07-07, 07:19 PM
LiCelsior
Retired
LiCelsior's Avatar
i dont think a ignition coil would cause the crap to run crappy. call up a dealer or contact one here.
Old 08-07-07, 07:22 PM
601LEXTACY
601LEXTACY's Avatar
its gotta be a coil though. Sounds like a sentra under the hood and not a 5.0 v8
Old 08-07-07, 07:30 PM
LiCelsior
Retired
LiCelsior's Avatar
4.0 v8 lol.
Old 08-07-07, 07:39 PM
601LEXTACY
601LEXTACY's Avatar
it stills souns like a lawnmower under there lol
Old 08-07-07, 07:45 PM
Och
Och's Avatar
99% its the coil, usually its the drivers side coil that fails, its kind of pain in the *** to remove, but not too bad... I managed to replace mine in about 30 minutes, I had to remove the battery and the battery tray.
Old 08-07-07, 07:51 PM
michael200
michael200's Avatar
I bought a coil at Checker (Kragen) for around $50.
Old 08-07-07, 07:53 PM
michael200
michael200's Avatar
Yes, a dead coil makes the engine run like crap, but it will run, and you can limp it home.
Quick Reply: Last chance before I give up....
