Started my Electric Fans Conversion today...
Old 08-12-07, 08:40 PM
avalon42
avalon42's Avatar
Default Started my Electric Fans Conversion today...
...boy, that radiator was NASTY.
Hit a snag in the project as the damned fan clutch nuts are on so tight, I couldn't get them off. I tried GENEROUS amounts of WD-40 to no avail. 2 of them are stripped pretty bad, the remaining two not much better off. So I'm still running stock for right now, but need to figure out a way to get those off. Too tight for a Dremel to cut off, anyone here have any suggestions?
Attached Thumbnails Started my Electric Fans Conversion today...-dscf0042.jpg
Old 08-12-07, 08:41 PM
avalon42
avalon42's Avatar
Ready to go, but I'm stuck...
Attached Thumbnails Started my Electric Fans Conversion today...-dscf0037.jpg
Old 08-12-07, 08:42 PM
avalon42
avalon42's Avatar
I installed a Transmission Cooler while I was at it.
Attached Thumbnails Started my Electric Fans Conversion today...-dscf0040.jpg
Old 08-12-07, 09:28 PM
LiCelsior
Retired
LiCelsior's Avatar
looks good, lol at all the wires and hoses and stuff. good luck and take progress pics if u can.
Old 08-13-07, 07:09 AM
Lexushead
Lexushead's Avatar
Torch them. Glow them nuts and they will come off.
Old 08-14-07, 02:12 PM
avalon42
avalon42's Avatar
I had to take my drill and drill those nuts out. They're out now, and I'm only stuck on one thing...where to tap the signal wire for the relay..
According to Lextreme, you can tap the ignition. http://www.lextreme.com/fan.htm
I'd rather tap the accessory wire, but don't which one it is. Anyone with a manual for a 92 LS400? HELP PLEASE, this project is stuck until this is resolved.
Attached Thumbnails Started my Electric Fans Conversion today...-dscf0002.jpg
Old 08-14-07, 02:13 PM
avalon42
avalon42's Avatar
Which wire to tap for accessory?
Attached Thumbnails Started my Electric Fans Conversion today...-dscf0003.jpg
Old 08-14-07, 02:16 PM
clsiorsldr
clsiorsldr's Avatar
I'd say just tap the ignition, and then run an electric thermostat (HKS makes a nice one) or, put them on there own circuit and use an electric thermostat, or just hook them up to a switch
thats how I'd do it; nice and simple
Old 08-14-07, 05:26 PM
Klierslc
Klierslc's Avatar
X2, the thermostatic relay makes it pretty nice. I used one on my aux fan for my Land Cruiser
Old 08-14-07, 07:42 PM
avalon42
avalon42's Avatar
Those are all good ideas, but I don't want to run it off the ignition. Anyone have the diagram or a repair manual?
Old 08-14-07, 10:24 PM
Suneet
Suneet's Avatar
I would post what info I have, but when doing my alarm install, I found that all the wiring info for the 93-94 is different than the 92.
Old 08-16-07, 12:02 AM
Klierslc
Klierslc's Avatar
Just probe that connector with a multimeter while an accomplice turns the key for you..
Old 08-16-07, 12:12 AM
TJW98LS
TJW98LS's Avatar
Don't tell HER that. lol
Im interested in the project, that looks pretty cool.
Old 08-16-07, 10:18 AM
Lexkost
Lexkost's Avatar
Do you want to sell that Fender Amp ?
What do you expect to gain by this mod ?
Old 08-16-07, 07:25 PM
avalon42
avalon42's Avatar
You serious on the Fender Amp? I have Line 6 equipment, so I don't use that hardly anymore. It's my beater amp.
I just want the engine bay to run cooler and free up a lil horsepower. I've been driving it around so far, it's accomplished that.
Quick Reply: Started my Electric Fans Conversion today...
