window removal?
Dutch,, sounds like you are doing alot of work on the ucf10. I see you found the service manual thread in the sticky section. You may want to check www.alldata.com as well. Requires a subscription, $24.95 for the year, but has some very useful information in there as wel.
No, but I've done them on a few cars and its pretty much all the same...remove all the trim and the weather stripping, and the obvious door panels and unbolt it from the regulator...for the windshields, you need special tools (special blades to cut the sealed glue). What windows do you want to remove?
i just want to remove the side windows, i also downloaded some stuff off of techinfo.toyota.com
yeah im doing some work on her, ill post some pics when im done.
Its Easy To Do Like avalon 42 Said Pull Out The Door Panels. Usually Theres 4 Screws On The Bottom. One Screw Under The Power Window Switch. Another Screw Right Under The Handle Where You Use To Close The Door. You Pop Out The Plastic Around The Door Lock. Everything Pushes Up. After That You Will See All The Screws For The Rails And Everything. I Did It Once On My 95 LS400 Because Stupid Plastic Broke That Goes Onto The Window Motor
PERRYinLA
Maintenance
30
02-05-06 04:55 PM
