LS400 Exhaust has room for a lot of improvement in HP
I put my car on a lift this morning for the 1st time and could see how much an aftermarket exhaust would be in terms of horsepower. There are 3 cats, 2 resonators and two mufflers. The way the 2 into 1 pipe joins, seems very restrictive as well as how they exit into the resonators. I think a quality exhaust would see 20hp gain.
Your thoughts?
Your thoughts?
I think you are right the stock setup is restrictive I guess to keep it quiet and efficient. I am not a mechanic but think with a good quality dual exhaust and hi flow mufflers you could see a 20HP increase. Hopefully somebody here has some dyno stats to be sure. I deleted the resonators and welded new pipe to the mufflers and couldn't tell you if I gained real HP by freeing it up. The muffler guy said it added power but who knows. It sounds better than before.
late much?
https://www.clublexus.com/forums/showthread.php?t=86174
https://www.clublexus.com/forums/ls-1st-and-2nd-gen-1990-2000/70132-1uz-fe-exhaust-system-tech-and-upgrades.html
https://www.clublexus.com/forums/showthread.php?t=62581
https://www.clublexus.com/forums/showthread.php?t=90823
https://www.clublexus.com/forums/showthread.php?t=89338
https://www.clublexus.com/forums/ls-1st-and-2nd-gen-1990-2000/86048-muffler-delete-mod-and-stock-parts-pics.html
Yeah I think you are on to something there - it sounds louder therefore it is faster. Somebody should dyno there LS before and after to put this issue to rest. Even if I gained no power at all it sounds nice.
