Key
I have one Lexus key. I need another one.
I am going to buy a blank key from ebay and have an ACE store cut it. Can this key start the car directly? or do I need to do any programing thing?
Is there a better way to get a spare key?
Thanks
Edit: It is a 96 LS4.
Thanks
ACE Hardware will not be able to cut it. You will need to have it cut by a dealership. What year is your LS400? If it's a 1990-1996, the key will work without needing any programming.
I have a 02 GS430(laser cut) and was told its $200 to get another master. That is if the key you have is a master. I have 4 keys. 2 masters, a valet and a wallet/flat combo. Older keys would be cheaper. They don't have to reprogram and lock out any missing keys.
If I were you, I'd buy one from Sewell for $42, and have them cut it. Might be cheaper that way, not to mention, OEM keys look much better
No programming is necessary.
http://www.lexus-parts.com/partdetai...bCategoryID=91
Use the CL discount code "CL911m" to get 10% off.
I bought one of those flip keys (like the ones used on mercedes) on Ebay for $30. A Local shop over here cut it for $20. The dealership wouldn't even cut it cause they wanted to sell me a new key from them. 96 LS400 btw. Works the same as the regular key I have
BomBum
06-13-21 05:31 PM
lexus02300
09-03-05 04:37 PM
