92 Ls400 Stock...rims??
Old 09-25-07, 03:04 PM
JFLACO610
JFLACO610's Avatar
Default 92 Ls400 Stock...rims??
Ok...what's My Best Bet If I'm Keepin The Lex Stock, No Drop...18/19/20???thanks Guys
Old 09-25-07, 03:18 PM
steveski
steveski's Avatar
I put 18's on mine and the gap was too much with stock struts - you'll want to drop yours when you see the gap unless the gap doesn't bug you. I dropped mine nearly 2" from this photo and now it is acceptable to the eye
I see so many cars that look like 4x4's - to each his own I suppose but little gap good big gap bad.
Old 09-25-07, 05:32 PM
JFLACO610
JFLACO610's Avatar
Default tires too
oh yea...n what size tires should i get too whether they were 18's, 19's or 20's????thnx again
Old 09-26-07, 12:28 AM
Matador
Matador's Avatar
If you dont plan on dropping DO NOT get 19's or 20's. You will ride crazy high and get that donk-esk look. The LS can pull off 18's with no drop, but they only look ok most of the time. If you wanna roll on anything bigger than a 17 I highly suggest you drop the car.
Old 09-26-07, 12:24 PM
19psi
19psi's Avatar
19" and larger lift the car off the ground, makes it look like ****. go 18" if you're not going to lower it.
depending on how wide a wheel you get, anywehre from 225 40 18 in front to 285 30 18 in the back.
Old 09-27-07, 08:58 PM
JFLACO610
JFLACO610's Avatar
Thnx Guys Ill Get On It N Post Pics
Old 10-02-07, 03:32 AM
lexmansc73
lexmansc73's Avatar
Default re: ls400 stock with no drop
I have 20" rims on my 91 ls400 and the look is nothing like a 4x4 or donk-ish the look is nice with stock suspention with no drop.
Old 10-02-07, 11:00 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
what tire size are you running....
Old 10-02-07, 12:21 PM
lexmansc73
lexmansc73's Avatar
Default re:tire size
im running 245/35/20
Old 10-02-07, 12:29 PM
pfantom68
pfantom68's Avatar
It won't look donk-ish with 20" rims, since the LS tends to work better with larger rims. However, you probably do have a fair amount of wheel gap, right?
And just a question, do you get any rubbing when you turn the steering wheel all the way in either direction?
Old 10-02-07, 12:48 PM
lexmansc73
lexmansc73's Avatar
Smile re:wheel gap
i feel the wheel cleareance is perfect check my photo also no rubbing turning left or right 20's belong on this car.
Old 10-02-07, 12:54 PM
PureDrifter
BahHumBug
i reserve my comments until after you post some useable images of your car (avatar image is too small...)
Old 10-02-07, 01:40 PM
Thermactor
Thermactor's Avatar
hey PD, while you're here - would the 18" LS460 wheels fit on the 2LS? They're 7.5" wide with a +32 offset. It seems as though they would fit, but the wording on the offset calculators online was a bit confusing to me.
Old 10-02-07, 01:47 PM
PureDrifter
BahHumBug
offset doesnt matter they wont fit.
LS460 uses 5x120 bolt pattern (first lextoy to ever do so, rest are 5x114.3 except the trucks)
Old 10-02-07, 04:47 PM
Thermactor
Thermactor's Avatar
holy crap are you serious?
that explains why i see their wheels going for less than scrap aluminum price on ebay
looks like i'll need these to make them fit
http://cgi.ebay.com/ebaymotors/Wheel...7860QQtcZphoto
and then it'll look like/be like crap because spacers suck
Quick Reply: 92 Ls400 Stock...rims??
