Daizen bushing problem?
The LCA bushings are popping out, I'm using a 5" C-clamp to push the center sleeve in and one bushing is sticking out 1-2mm. What seems to be the problem here?
when i had the bushings swapped in my camry (polyurethane from Armstrong) i just took them down to my local NAPA and had them press them in (they took the old ones out too
sounds like u arent using enough grease and/or not enough force. do the bushings appear to be seated properly?
) for ~$9/each
(total was 36 for both lower arms, theres 2 bushings in each)
Ok, here's what I am doing:
UCA/LCA bushings. UCAs slipped in with no problems. Now, when I went to finish the LCAs, the bushings themselves slipped in with no issues, they were flush with the arm at this stage. I began to have trouble with the metal sleeve, it went in 1/2 way fine, but as soon as it began to enter the other bushing 1/2, it wanted to pop out. So I used a 5" c-clamp with 2 11/2" washers and press the sleeve and the bushings in. That worked to seat the sleeve in, but now the opposite bushing half is a good 1-2mm out, I can use a vise or C-clamp to squeeze it in, but it sticks right out. What can I do at this stage?
BayAreaLex
11-05-12 03:59 PM
Bradster
03-15-09 05:53 AM
en11871
02-26-08 08:27 PM
