Magnaflow Wide Open Series 95 LS400
Looks great by the way, very clean
One last of the side:
YouTube video to follow to see and hear them![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
Hopefully this will help some of you that are considering changing the OEM setup. So all I have now is high flow mufflers and no resonators. I still have the OEM Y-pipe - may change later to X pipe and duals. For now, this is just fine.
so this is what you've been up to these last couple months
post up a vid, il try to clean my car off this weekend too and post up my setup
I spoke to Lexkost and he told me how to do it - it was really easy and took just a few mintes. $400 seems OK but my guy said $100 to run the duals then $40 per side. I would have to buy the X pipe though. There is so much here about running duals and affecting velocity thereby affecting acceleration I decided to hold off until I could get more information. This setup sounds better than the stock mufflers and no resonators and changes the look.
Sorry - yes I cut them myself. I asked Lexkost how he did his before he swapped to the LSportline bumper. You can use either a Dremmel or a good utility knife. Before I cut it the muffler the tech held the muffler up so I could be sure I cut it out right. It cut real easy - nothing to it. All I need to do is hit the inside with black paint now.
Man I posted 3 videos under steveakasteveski:
Lexus LS 400 MagnaFlow 14225
I see them in YouTube My Videos but I can't find them when I search![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
I have a nice digital video camera but the quality didn't come out so good. I converted to MPEG1 Best Quality - seems like it should be clearer.
Now that I know what I am doing I will make another video tomorrow that will be better hopefully.
Geez
Easier than I thought
Here's the driveby under moderate acceleration:
http://www.youtube.com/watch?v=6ar-U6oKNo4
Here's one under harder acceleration:
http://www.youtube.com/watch?v=jCfSwY8UWoA
Here is a moderate take off:
http://www.youtube.com/watch?v=682JDiOSifQ
It sounds still different in person than on camera. Now that I kind of know what I am doing I will make another video tomorrow. Remember this is the stock y-pipe with no resonators and two MagnaFlow 14225 mufflers. It is about twice as loud as before with the OEM mufflers and no resonators.
Overall I like it. This setup is quite a bit cheaper than Apexi's which I liked as much. The Apexi's were fatter and would hang down more.
Hope it helps some of you out there.
