Ball joint replacement
Old 10-21-07, 08:46 PM
ttyR2
ttyR2's Avatar
Default Ball joint replacement
Are the ball joints themselves available as a part that can be replaced in A-arms and such (using a hydraulic press)?
Old 10-21-07, 08:51 PM
LiCelsior
Retired
LiCelsior's Avatar
here yah go! http://www.lexls.com/tutorials/suspe...flowerarm.html
Old 10-21-07, 09:09 PM
trukn1
NELOC Mod
trukn1's Avatar
The only ball joints which cannot be replaced separately are the front uper ones'. They are part of the control arm and have to be replaced as an entire unit.
Old 10-21-07, 09:12 PM
akxx
akxx's Avatar
Lower ball joint--yes (and very simple to do)
Upper ball joint=replace entire UCA.
Old 11-08-07, 03:10 PM
tnltracy
tnltracy's Avatar
Does this How - To apply to 1996 model year also, or did the front end change in the 95-97 models?
Old 11-08-07, 04:04 PM
sonyman
sonyman's Avatar
It changed, but they are still similar enough that the howto should apply just fine.
Old 11-08-07, 06:17 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
basic suspension design is the same, LBJ is easy change, UBJ is only done by replacing full UCA.
Old 11-08-07, 07:30 PM
Thermactor
Thermactor's Avatar
LBJ job is so easy on these cars, a cavegirl could do it. God it's SOOOOOOO EASY. The only special tools you need are a basic torque wrench and a ball joint puller tool from autozone that costs 12 bucks
Old 11-08-07, 07:38 PM
tnltracy
tnltracy's Avatar
thanks. just gotta find me some LBJs then...
Old 11-08-07, 07:57 PM
Thermactor
Thermactor's Avatar
they're very expensive about $150 from a discount (25 percent off) dealer for the pair.
Old 11-09-07, 01:27 AM
PureDrifter
BahHumBug
you can get them OEM for <$160/pair....
Old 11-09-07, 02:28 PM
tnltracy
tnltracy's Avatar
Thanks puredrifter. Where have you seen them that cheap? Best I've found so far is about $90 each, haven't found pairs for 96 model year. Gen 1 versions I've seen cheaper, but not Gen 2
Old 11-09-07, 04:06 PM
PureDrifter
BahHumBug
carson sells them....
hell, i remember seeing a set of OEM LBJs on ebay.
Old 11-09-07, 05:57 PM
pierre506
pierre506's Avatar
Wink
I wholly changed it last month. The part couldn't be separated.
Old 11-09-07, 06:12 PM
PureDrifter
BahHumBug
lower ball joint or upper.....
Quick Reply: Ball joint replacement
