Help, my moonroof might be leaking
Old 10-26-07, 09:32 PM
lexy1
lexy1's Avatar
Unhappy Help, my moonroof might be leaking
So for the past couple of days it has been pouring down raining. My drive side is soaked from the ceiling to the floor. What should I do? I called the lexus dealership and they said it cost me from $50 to hundreds of dollars to find the leak. Any advice?
Old 10-26-07, 11:17 PM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
Make sure the drain lines are connected. There are drain lines that run from each side of the sunroof (driver, and passenger) that lead into the trunks outer sides.
Seems like your drivers side is either disconnected, or plugged with dirt. Double check and make sure the drain tube is connected to the line.
Common issue by the way.
Old 10-26-07, 11:21 PM
Iansaltes
Iansaltes's Avatar
I had this same problem... I took it to Lexus and actually they fixed it for free... didnt take them long at all.
Old 02-16-09, 01:14 PM
LSfour
LSfour's Avatar
Two weeks ago when it started raining here in the bay area, my wife complained about some water dripping from the driver side. Just today I read this forum and tried checking the drainage hole and found it was plugged with some dirt. I cleaned it and tried pouring some water and noticed water dripped near the rear wheel. I guess that means the drainage finally worked.
I'm gald I found this issue here and don't have to send the car to for servicing. Thanks!
Old 02-16-09, 02:02 PM
420man361
420man361's Avatar
i'm tryin to fix mine, same problem, where's the drain lines located at?
Metlupass2
06-11-21 10:15 PM
14ES350
ES - 6th Gen (2013-2018)
03-11-19 12:58 AM
ar3
SC- 1st Gen (1992-2000)
11-01-16 12:03 PM
avelez8328
RX - 1st Gen (1999-2003)
02-22-16 08:40 AM
whokidd
11-19-13 12:45 PM
Quick Reply: Help, my moonroof might be leaking
