Differential lube...
Old 11-09-07, 01:55 PM
pfantom68
pfantom68's Avatar
Originally Posted by Bill Dowd
All The Above Synthetic Oils Are Great I Use The Redline Gl5 For Limited Slip Rear Ends Which Some Of The Lexus Rear Ends Are. Yes Synthetic Lube Does Cost More And That Is Why Bmw Mercedes And All High End Cars Are Now Using It Including Porche And They Change The Motor Oil At Around 15to 18,000 Miles And No Problems. Amsoil Is Probably The Best Followed By Mobil One Redline Royal Purple Etc. They Are All Very Good For The Lexus By The Way Somebody Took A 99 Lexus Supercharged The Motor To 1000 Horse Power With Out Any Modification And It Has No Problems This Is How Good The Lexus Motor Is Anothe Story Is That The Lexus Motor Is The Only Car Motor That Can Come From The Crate And Put Into An Airplane The Only Car Engine In The World That Is Able To Do That Faa Approved Due To It's Quailty. Bmw Mercedes Try That.
Umm... what does most of that have the slightest bit to do with anything being discussed?
Anyways, I just changed my diff oil on Tuesday... replaced it with some Mobil 1 synthetic 75W-90. Next up is to change my trans mount and flush the transmission fluid.
Old 11-09-07, 04:11 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
bill, you gotta stop just saying things
first off, the max. ive ever seen anyone take a 98-00 1uz motor has been 500hp. the 1st gen can take a lot more power but 98-00 had MUCH skinnier/weaker rods than the VVT-i model.
got any sources for your FAA claim as well?
oh, and no Lexus, aside from the 1st gen IS, came with an LSD option.
first you started off with the whole "i put regular mobil1 atf in my trans and it works" claim, which we all know is untrue, and now this.
Old 11-10-07, 12:48 AM
damon
damon's Avatar
This is Gear Oil folks!!
If you are as ignorant as some of the people posting here it is quite likely that you would do more harm than good attempting this procedure.
If you do not have the capacity to suction the old oil from the rear diff you are not smart enough to proceed!!
Old 11-10-07, 01:37 AM
PureDrifter
BahHumBug
If you do not have the capacity to suction the old oil from the rear diff you are niot smart enough to proceed!!
suction
theres a drain bolt....
id just flush some new oil through it with the drain open to get the leftover fluid out, put the drain bolt back, and fill it up.
Old 11-10-07, 10:34 AM
kwikrnu
kwikrnu's Avatar
Synthetic may be better, but didn't toyota just fill these with convential from the factory? I sincerely doubt mine has ever been changed and I am at 155k miles with no problem. I doubt a synthetic oil in the differential would make a huge difference in how long it lasts. Use regular convential oil and change it every 100K miles and you should be okay. I'll use walmart 80-90 supertech oil when I get ready to change mine.
Old 11-10-07, 07:41 PM
pfantom68
pfantom68's Avatar
Well... let's not get into another conventional vs. synthetic debate here.
I use synthetic for the peace of mind and placebo effect. I use synthetic motor oil and I've noticed I get slightly better gas mileage (I also did other things, so that may actually have no effect) and it helps me sleep better at night. How much of a difference it makes, I don't care. I'm ready and willing to pay 2-3x as much as "normal" gear oil or motor oil just to make myself feel better.
Old 11-10-07, 08:10 PM
sonyman
sonyman's Avatar
In a car that doesn't tow anything, isn't driven hard, and isn't subjected to extended drains, or other harsh conditions, synthetic gear lube won't make a noticeable difference. I personally use Red Line 75W90 synthetic gear lube for the added protection it offers, but with or without a synthetic, my differential will be just fine for the conditions I subject it to.
Old 11-10-07, 08:19 PM
pfantom68
pfantom68's Avatar
Well... I probably put more strain on my drivetrain than 98% of Lexus owners. I really like to drive it hard, so synthetic gives me the peace of mind I desire.
Old 11-10-07, 09:55 PM
Lexmex
Super Moderator
Lexmex's Avatar
For my transfer case and rear differential in my RX, I use Royal Purple 75W90 and I put MAJOR STRESS on my drivetrain. (see photo at left)
However, I think anything like Amsoil, Redline, Mobil 1 or Royal Purple is just fine for the uses you have.
Old 11-12-07, 11:03 AM
damon
damon's Avatar
I also use Royal Purple 75W90.
I would guesstimate that I am not at all hard on my drivetrain.
I meant that you need to have the inexpensive little pump to refill the diff completely.
Old 11-15-07, 05:47 PM
Bill Dowd
Bill Dowd's Avatar
OOPS THANKS FOR THE UPDATE ON CAPS
Bill
coachz
RX - 3rd Gen (2010-2015)
02-25-19 12:21 PM
ajay60610
02-19-17 07:14 AM
krue92
IS F (2008-2014)
15
08-23-11 03:50 PM
rexlex
RX - 1st Gen (1999-2003)
12-22-06 08:09 AM
1994 LS400
03-07-02 09:23 AM
Quick Reply: Differential lube...
