Can I add an MSD blaster coil to the LS ignition?
This is the first time I have owned a car that had a distributor in awile, so I dont know too much about the ignition. I was just wondering if I could add an aftermarket coil? I only mentioned MSD because that is a pretty good brand if it is used on a Top Fuel car.
Also, I never got an owners manual or any sort of manual when I bought the car so I dont even know where the coil is. Can someone help me out with some pics, thanks.
Sounds like a solution looking for a problem. Are you expecting some sort of performance increase by changing out the coil, because that's not going to happen unless the existing ignition system has problems.
