Help!! 1994 LS400 Engine hard to start in morning
I just took my car down to PepBoys to have them check on the engine and fuel system. Everything checked out well from fuel Pressure to Spark plugs. The guy said the engine runs really fine and could not find the problem. He was actually starting engine just fine everytime.
Then as I was leaving, the problem surfaced again and the car wouldn't start. He immediately checked it and told me it may be the anti-theft device (original manufacture) that's preventing the engine from firing up. He fliped the key and reinserted, cranked and the engine fired up immediately. So his recommendation was for me to bring the car to Lexus Dealer and have them check on the antitheft security system.
Any ideas? I guess I may just have to bring it to the dealer.
So does the immobilizer in my 1994 LS400 actually kills the electricity to the starter and prevent cranking all together or it kills fuel and spark and allows starter to crank and the engine to barely start and choke a few times before it dies? Because my engine does choke and barely starts when I am having trouble starting it.
Is there a way to turn the immobilizer off? or disconnect? or disable it? I know just turninig off the remote key entry is not enough.
Can the problem be with cold start injector?
Actually the problem even starts to happen when I try to start the engine warm now, like my car sitting for about an hour during the day. It's completely unpredictable now. Sometimes engine fires up right away first time in the morning. Sometimes it takes 5 tries and the engine would choke and barely start before I finally fire it up after car sitting just for an hour during the day.
I can really use some help.
BahHumBug
you dont have one.
You're right. It's a starter kill. The starter wouldn't even crank when the alarm was triggered.
The frequency of this problem is getting worse. I made an appointment with Lexus Dealer next Tuesday Morning. I hope they will be able to figure it out. I will keep you guys posted.
BahHumBug
No. All LS400's have an immobilizer. 1997+ have an additional transponder-linked immobilizer feature that will allow the starter to operate, but prevent the engine from actually starting if an unauthorized key is used.
The starter kill is the immobilizer. However, the immobilizer on 1990-1996 LS400's will prevent the activation of the starter circuit, preventing the starter from operating at all.
I see your point, but just for technical accuracy, I'll continue to refer to the early system as an immobilizer, as called so by Lexus.
Brought by LS400 to the dealer this morning. Of course it took me about 3 tries to fire up the engine and the dealer didn't have any problem firing it up. They gave me a loaner car and will let me car sit for a while to see if they can duplicate the problem. Told me it should be either the fuel pump, cold start injector or the starter. There was fuel pressure, so the guy is leaning toward the starter. He said that the starter may be cranking ok but not engaging sometimes. he will let me know when they can duplicate the problem.
How much would be a fair charge to replace a starter or a fuel pump or a cold start injector? I will keep you guys posted.
