Well I finally replaced the propeller shaft assy - '95
After dealing with an annoying vibration affected by speed and throttle pressure for a year now, I finally replaced my entire propeller shaft assembly. This includes the two segments, the support bearing, and the flexible couplings. It was expensive, let me tell you, but it seems to have eliminated 95% of what I was feeling. To get the remaining 5%, I think I'll have to replace the mounts, which is next on my agenda, although it may be a little while. Surprisingly, the old propeller shaft segments looked OK; there was a tad of corrosion on both segments, but they didn't look that bad. Also, the flexible couplings looked perfect. Obviously, however, it doesn't take much to warp or damage a driveshaft as mine was clearly faulty.
Expensive? You probably didn't do the work yourself then.
Also, it's not the segments that cause 99% of problems. It's the bushings and the actual joint. Even though it might seem solid out of the car, it may not be doing the job when you're putting 250lb/ft of torque through it.
I replaced my driveshaft back in June. It wasn't too difficult at all. We did it in my friend's driveway using an impact wrench, some ratchets, sockets, wrenches and a hacksaw.
I bought the used driveshaft out of a 92 w/ 102k with a good-condition joint for $100 at a local junkyard.
So far it's been great, but I have yet to change my trans mount.
It had nothing to do with not doing the work myself. I bought a brand-new driveshaft assembly. I paid very little for labor, and a good deal less than retail for parts as a dealership employee.
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
Expensive OEM parts and a lack of aftermarket is what sometimes makes me wanna just go buy a Trans Am and call it a day. But I just love my Lexus too much.
Is this a homeland security issue we're talkin' about... or a driveshaft ?
Normal trade discount (jobber) is 10-20% some employees get 25% depending on the part.
Doesn't matter what the discount is that you get , as you are not going to give it to anyone here.
It will however allow some of us to find a baseline for some dealers to try and negotiate for more of a discount as the wholesale price is part dependent.
Well net price (my price) was $584.30, and the current labor rate is $50 per hour. I paid $40 per hour x2 hours, however, so it may depend on the type of service. Out the door it was a tad over $700 dollars.
did your vibrations come and go at freeway speeds? just kind like a slight vibe you could feel in the seat and see the shifter doing? i think mine is also in the driveline. are they not rebuildable? i doubt if the acual tubes are bad, it's got to be the u joints and bushings...
