Dyno of my 99 LS400 / Wild Ride in a 450whp EVO
Old 11-15-07, 09:26 AM
timer00
timer00's Avatar
Cool Dyno of my 99 LS400 / Wild Ride in a 450whp EVO
Hey everyone,
Just went to CBRD SpeedFactory in York PA where my friend takes his EVO IX which has about 300whp last night.
Got my car dyno'd on their Mustang Dyno (the lower reading one that puts a load on the vehicle unlike Dynojet for those who know about dynos)
But first Chad from CBRD was trying to convince my friend to upgrade his car with the parts from this other clients car who was upgrading even bigger. I went out for a ride in this car with the Chad and my friend. It dyno'd about 450 on their Mustang dyno recently and man for my first time ever in a turbo car really with any real power (not counting a talon TSI stock or two I been in which doesn't compare) it was just nuts.. through the 1st-3rd I was pinned back in the seat and thought I was going to die, remember I am not used to anything other than my LS which is the fastest car I ever been in (I don't get out much lol).
Anyways I took a few short vids of the dyno which I'll post later maybe depending on their size.. otherwise heres the link to the dyno sheet.
1999 LS400, Muffler Delete, Jbrady Mod (which doesn't really do much on a dyno)
http://www.tamaquatech.com/t1m3r/dyno.jpg
The one top guy who was showing some customers around right when my car was getting dyno'd said.. "Well it is probably the quietest car we ever had on this dyno". That made me LOL.
For some reason he only took it up to max 5600 or so rpm on the sheet. I am thinking the HP figure might be down about 4-5hp maybe so otherwise there ya go.
It might be low figures I don't know since I found a bunch of GS400 dyno sheets via search function on Dynojets which is different and none that I can think of that dyno'd their 98-00 LS400 with a sheet via the search.
Enjoy
Old 11-15-07, 09:57 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
the GS gets a bit of a tq advantage thanks to the better/lower rear end gearing.
i needa get dyno'd soon
Old 11-15-07, 11:47 AM
TJW98LS
TJW98LS's Avatar
Wow, we need more power. Looks like these mods do nothing for our cars.
Old 11-15-07, 03:19 PM
turbosix
turbosix's Avatar
muffler delete's biggest advantage is weight savings... c'mon now
Old 11-15-07, 04:32 PM
RA40
Super Moderator
RA40's Avatar
Thanks for posting your pull results.
The mods are small increments and for the most part, probably not obvious. Like OC'ing your pooter, 10MHz is minimal but add up enough tweaks and it may be nice. Now if you can bump it 25-50 HP, I think you'll notice it. 1-5 HP...nah.
Old 11-15-07, 04:37 PM
TJW98LS
TJW98LS's Avatar
Putting your car on a diet can be nice. I had my spare out of my car for the longest time, until I realized when I parked next to another LS, that my rear end sat alot higher...now I drive with the spare in, and 60Ibs sure does make that much of a difference.
Old 11-15-07, 06:37 PM
steveski
steveski's Avatar
Maybe a Supra diff would fit.....? With slightly lower gearing that could be the biggest difference with no added power. Anybody know if it will fit?
Old 11-15-07, 07:59 PM
PureDrifter
BahHumBug
if i could find a supra TT diff around here for under a grand id be more than happy to test fit.
thing is, iirc theres a difference in the rear end design between 95-97 and 98-00
Old 11-16-07, 05:52 AM
Zoraone
Zoraone's Avatar
Some things to remember:
1. Did you make one and only run on the dyno? I've had GM F-bodies/LSx cars on a dyno make bigger numbers on the second and third run due to timing increases, etc. As long as the heat soak doesn't set in.
2. You're lacking about 500rpm on the chart. Horsepower was still building and its peak was the point the dyno session ended.
3. As you stated, it is a Mustang Dyno so the peak numbers are lower than you would typically see on a Dynojet. ie an LS2 GTO will produce about 330hp at the wheels on a Mustang Dyno and about 350hp at the wheels on a Dynojet.
Old 11-16-07, 11:52 AM
Thermactor
Thermactor's Avatar
yep, n/a power adder bolt-on mods on an LS are like rearranging the deck chairs on the titanic
do what i'm doing and get blown :P
Old 11-16-07, 12:02 PM
timer00
timer00's Avatar
1. The shop owner did the runs 4 in all for $75. The first 2 were tuning runs because he isn't used to dynoing automatics (shop runs mostly EVO's, STI's, Audi's AWD manuals etc) due to them not staying in gear and dropping down.. apparently you have to rev to 4000 before going WOT on the dyno with the lexus autos otherwise they kick down. The last 2 runs are whats on the dyno sheet.
2. I didn't get a chance to ask the owner about the 400-500rpm shortage on the sheet.. like I mentioned in my post I am "guessing" 4-5 more whp maybe if it went up to 6000 where the LS supposedly makes its peak 290 crank.
3. Yes the whole dynojet / mustang thing that some people tend to get confused. I have read on G35/Corvette/Ford etc forums through google depending on a bunch of things the % difference between dynojet and mustang is generally 10-15%. So I figure my numbers on a dynojet would be similar to other stock GS400's that I have seen dynojet dynos for.
Also I didn't ask many questions regarding what gear he was in I just know he had the PWR ETC mode on when I left the shop so I assume he had that on. Traction control was left on and didn't cause a problem. Hood was closed and just a fan in front of the vehicle. I plan on going back in the early spring after a full catback exhaust and my suspension mods are done to get a new reading using the same dyno so hopefully the #'s will at least go up so I don't get totally depressed haha.
Old 11-16-07, 03:20 PM
turbosix
turbosix's Avatar
it would be done in whatever gear is 1:1 for your car
3rd gear for most 4spd autos
Old 11-16-07, 05:33 PM
timer00
timer00's Avatar
Thanks, I reviewed the video I had and it was 3rd gear.
ultm8mind
Build Threads
26
10-06-17 06:27 AM
Jeremiah87
23
09-20-13 11:35 PM
bwilsongs
06-24-13 08:07 PM
Quick Reply: Dyno of my 99 LS400 / Wild Ride in a 450whp EVO
