98LS - Noise from suspension when braking
The noise sounds like it is coming from the suspension system (struts, sway bar, control arms, etc). The car only has 85K so I doubt is would be worn out struts already. The car rides very smooth with no noise during regular driving. The noise only occurs during braking. The brakes have less then 10K on them so I would assume it is not coming from the brake system.
Thoughts?
Fran
Thoughts?
Fran
You will hear a heavy clunk when going over parking lot humps or a driveway curb. It's worse if you are braking at the time.
I don't think that mileage is as much an issue with these as age...the rubber breaks down.
New strut rods complete with bushings can be had for a little over $100 ea and they can be installed in an afternoon with basic tools.
I see that I can get just the bushings (less the entire bar). Is this an option or is purchasing the entire bar assembly a better way to go? below is a link to a video I found that shows the steps for replacement. Any other steps that I should be aware of?
http://photoshow.comcast.net/watch/Fj9WH6CM
Fran
Fran
Fran
Fran
![Doh!](https://www.clublexus.com/forums/images/smilies/doh.gif)
Fran
Fran
I would just note that I encountered the same issue on my 97 LS 400 at around 85k miles. Rear bushings a little earlier. I definitely drove that car harder than I should have, though.
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
Coulter
08-14-13 05:54 PM
