Headlight Question
Old 11-18-07, 05:45 PM
Smoothie22
Smoothie22's Avatar
Default Headlight Question
I have a 99 with HID headlights and my drivers side bulb went out tonight. I haven't had a chance to look at it and wanted to ask how hard they are to change without messing up the auto level? Should I just take it to Lexus? Does anyone know of a good source to get bulbs? I am taking the DR2 35 watt bulb is the HID bulb. Any information on this would be greatly appreciated.
Old 11-18-07, 09:55 PM
skperformance
skperformance's Avatar
ebay is cheap for oem bulbs.
Old 11-19-07, 12:22 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
http://www.theretrofitsource.com/Bulbs.html is a good place for bulbs (OEM or aftermarket, they offer the OEM bulbs in D2R as long as u call/contact them)
Old 11-19-07, 08:11 AM
19psi
19psi's Avatar
very easy to replace, just like a regular bulb.
Old 11-19-07, 09:28 AM
Smoothie22
Smoothie22's Avatar
Thanks for the replies everyone. I actually got into my car this morning and oddly enough they were both working. Really strange. Has anyone ever had this happen to them before?
Old 11-19-07, 04:11 PM
PureDrifter
BahHumBug
ballast could be failing.
Old 11-19-07, 07:00 PM
Smoothie22
Smoothie22's Avatar
The ballast huh. That sucks, can't see it being a cheap fix
Old 11-20-07, 12:12 AM
PureDrifter
BahHumBug
just see if it starts happening constantly
if it does, then swap the bulbs side to side, if it still happens on the same side then its the ballast, if it switches, its that bulb.
Old 11-20-07, 06:35 AM
19psi
19psi's Avatar
^^^ what he said. easy fix, but the part would be pricey. look for used if possible.
Old 11-20-07, 12:26 PM
Smoothie22
Smoothie22's Avatar
Thanks for the replies and ideas. If it happens I will definately try that and see what happens!
Old 11-21-07, 12:21 AM
Bill Dowd
Bill Dowd's Avatar
wait till you see the price on the bulbs hold on to your hat.
Old 11-21-07, 01:18 AM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
I had the same problem, and its usually the bulbs start acting up of old age. Sometimes only one side would turn on, and I would have to turn off, and turn them back on. Replacing the bulbs with Phillips D2R will most likely fix the problem.
I STRONGLY recommend you replace them as a pair, if you want them to match in color, and output. Also, type of bulbs doesn't effect the auto leveling, as the entire housing moves up and down, so you shouldn't have any problems if you use a standard philips D2R bulb.
Old 11-21-07, 01:24 AM
PureDrifter
BahHumBug
$60/70 for a pair+shipping isnt as bad as some high end PIAA halogens
Old 11-21-07, 11:48 AM
Sanpete
Sanpete's Avatar
GLS4 recommends Phillips. Any thoughts on brands? eBay has lots of cheaper ones.
Is the stock color 4300K? It appears you get more light (lumens) with that color.
Old 11-21-07, 08:16 PM
PureDrifter
BahHumBug
phillips/osram is OEM issue at 4100/4300k.
just buy them OEM from the sites ive posted, the aftermarket ones arent much cheaper at all and the quality is sometimes dodgy.
Quick Reply: Headlight Question
