rear ate rotors for only $26 each at tirerack
Why are these so cheap compared to most other prices? I wish they had the front too then I wouldn't even bother to check the runout of each rotor before purchasing
I replaced the front rotors 20k miles ago using brembo replacements that cost about $50 each from thepartsbin.com but it seemed like they were warped again after only 10k miles. At least there is plenty of vibration when braking at highway speeds. I am going to check the runout to see how bad they really are. I can't believe rotors would warp so easily especially since the car is not driven hard.
you dont have to replace warped rotors, you're supposed to have them cut.
il prolly try out the ATE rotors when i needa do the rear brakes, i posted up a thread askin bout them in the wheels/tires/brakes forum and didnt get any reviews.
at this price i'll buy new rear rotors before having them turned for $15 each. i haven't had much luck from having rotors turned for other vehicles. The few times I've had rotors turned it seemed like they got warped almost immediately.
Read the post. ATE is a Euro parts Co with quality. I have a CLK 430 & I chose not to use their rotors when I re& re'd. Why; I found slotted/drilled rotors & carbon-kevlar pads. ATE had a funky Beehive groove in what was more just solid rotor. I do use ATE DOT 4 brake fluid. I have a CF2 & will change to drilled/slotted rotor. My son has a CF1 and needs new rotors. I'll help him replace his & this might be good thing for him.
P.S. If you warp a rotor, I have never resurfaced a rotor. Reason being heat. Or more specifically heat transfer. What causes a rotor to warp is excessive heat. By trying to resurface a rotor you actually decrease the amount of heat a rotor will absorb. Causing it heat up faster and soak up even less heat. Thicker rotors will always absorb more heat. Warping is a sign of built in manufacturer flaw most likely due to recycling parts from existing cars not built to withstand weight of newer cars.
The issue here is the cause of heat and its effect on the brakes. Once a rotor is overheated and eventually warps; its finished. That process of heating the metal distorts its shape permanently. Regardless of what you try do after the fact. Think of it it terms of bending a spoon. It will never have the originally intended strength or stopping capability.
Warping a rotor and resurfacing it, doesn't fix anything. It will cause it to re-fail(warp) faster. If you don't have the funds or can't replace the rotors, by all means resurface the rotor knowing the life expectancy will be extremely short at best and you will replace them after all. But most importantly, you will be compromising/deminshing your cars braking ability.
Yes, resurfacing a rotor is a method of alternative replacement. Allowing virgin surfaces to have maximum contact and smooth action during a break-in period.
Resurfacing rotors isn't a cure for warping rotors,it will return almost immediately after you have spent considerable money and most importantly time you will throw away and replace to correct. When its a warped rotor: save time and money. Buy new rotors that are safe and will renew full braking ability to your Lexus.
you have to understand, when people think of "warped" rotors they have the misconception that the ROTOR itself has deformed, which is simply not ture. what happens is that pad material is unevenly glazed onto the rotor, throwing it out of balance.
enjoy
http://forum.e46fanatics.com/showthread.php?t=402902
http://www.stoptech.com/tech_info/wp...rakedisk.shtml
"Thickness Variation due to hot spots". Call it what you like. What you have is a rotor that has a high/low spot. If resurfacing works, thats the way to go. I see no proof it corrects the underlying original problem. Meaning you will only prolong the inevitable replacement
rotors are wear parts. its like you're *****ing about having to replace brake pads or change your oil.
and little ghetto shops will turn rotors for $5/ea, no reason to go to some chain store for that...
the "Thickness Variation" isnt in the METAL of the rotor flexing, its glazed on layers of pad material affecting the OVERALL thickness of the rotor. im not trying to PROVE anything to you, i gave you the facts and you have yet to show me ANY EVIDENCE AT ALL that what you've been saying has any sustainable merit whatsoever.
there is not underlying problem with the ROTOR, its pad choice and circumstance
consider this, if what you are saying is true, then what reason is there for manufacturers to give min. thickness specifications for rotors, if once they get "warped" they need to be replaced.....?
