Power steering noise in cold weather help!!
SYnthetic fluids have better properties of breaking down debris and keeping it suspended in the fluid so it does not cause the blockage again which would make the noise reduce if not stop it completely.
In My Above Statement The Reason For Mobil One Synthetic Transmission Fluid In The Power Steering It Remains Fluid In Cold Weather And Start Working As Soon As You Start The Car. I Learned This Trick From Friends In Alaska Where Mobil One In Used In All Cars And Is Used In All Applications From The Motor Power Steering Trans And Rearend Be Cause It Will Flow To 50 To 60 Degrees Below O
01-13-17 01:57 PM
