1990 LS400 "rims for snow tires"
Old 12-05-07, 08:19 AM
kwikrnu
kwikrnu's Avatar
I had a 2003 corolla and I used some bridgestone lm-22 snow tires for a few seasons and they worked very well.
Old 12-05-07, 09:00 AM
manli99
manli99's Avatar
Default 19psi
Thanks for confirming my suspicion on Mercedes. S320 is especially heavy, wish my brother has a smart car to give away.
Old 12-05-07, 09:02 AM
heyhowyado
heyhowyado's Avatar
Originally Posted by 19psi
would you like to be able to stop and steer around corners? if you answer yes, then yo uneed 4 snow tires.
there is a jaguar in my bay right now that has only 2 rear snow tires.... i can't wait for him to call in and get 2 more once it snows and he realizes he can't stop!
hmm....i've just never known anyone to get 4....
but ok, that makes sense...
Old 12-05-07, 11:11 AM
19psi
19psi's Avatar
usually because they have someone giving them advice who doesn't know **** about tires!
Old 12-06-07, 01:38 PM
manli99
manli99's Avatar
Default light weight alloy wheels
I have decided to go with tire rack. The preferred winter package (same size as the the set on my LS400 right now) is a 15 inch light weight alloy rims (15.4 LB). Is it a good idea to have such a light weight rims? If I would like a little extra ground clearance without sacrifice safety what options do I have. I am a car idiot, do excuse my indecision. Please help!
Old 12-07-07, 08:26 AM
19psi
19psi's Avatar
tire rack is a good choice. light weight wheels are always better, they give better mileage, braking, acceleration and handling.
ther'es really nothing for increasing ground clearance though. a slightly larger tire would get you maybe 1/2" higher, which wouldn't really help much.
get the snow tires and you'll be fine for all but the heaviest snowfall. for that, i guess you're stuck at home or buying a jeep! i have a lifted jeep for bad weather.
Old 12-07-07, 09:44 AM
manli99
manli99's Avatar
Default 19psi
Thanks!!!! I will go ahead and go for the preferred package. We have a slight slope at the end of our drive way (~15-20 degree). The bottom scrapes a bit once a while when the car is loaded. I wonder how the rest of you with dropped chases avoid situation like this? Thanks again!!!!!!
Old 12-07-07, 09:47 AM
LiCelsior
Retired
LiCelsior's Avatar
the front or the back scrapes? u can try some wooden planks so u dont scrape.
Old 12-07-07, 11:29 AM
19psi
19psi's Avatar
i go on extreme angles to avoid scraping. even then, sometimes it's unavoidable. par for the course i guess...
Old 12-07-07, 01:02 PM
manli99
manli99's Avatar
Default scraping
Hi LiCelsior, I think it scrapes in the middle. I try not to load up passengers till I am over the danger zone. The low rider does look elegant. Thanks you all!!!!
IK828
02-18-10 06:23 PM
EastWind
12
01-03-09 01:07 PM
kyang91
10-15-08 08:28 PM
Pezhead
03-07-05 10:44 PM
skyman
Wheels and Tires Classifieds
07-20-04 04:09 AM
Quick Reply: 1990 LS400 "rims for snow tires"
