electrical problem question 1991 ls400
Here's the description.
The radio will not play when the key is in the acc position.
When many accessories(heater fan, seat heater, windshield wipers) are turned on when the car is running the radio will cut off.
At a stop sign when the car is turning less rpm's the radio will cut off and the dash lighted up Christmas tree style.
I was thinking it may be the battery, but the car starts fine every time. The lights are very bright and do not cut off when the car is turned off. It probably isn't the alternator because the battery stays charged and the system runs pretty good unless nearly all of the accessories are turned on at the same time. I'll probably take the car to autozone and have them test the battery and alternator first just to be sure.
I'm thinking maybe a loose connection or a bad ground somewhere.
Anyone have this problem before?
It sounds like you need to have a load test performed on your alternator. Just because the battery is being kept charged doesn't mean the alternator is not the culprit. It's a good place to start in any case. It could also be a grounding issue like you mentioned, or a loose connection at the ground/body connection point.
I thought that might be the problem because the dash light comes on occasionally. The amber one with the rear lights. I removed the wire harness from the trunk lid arm because it was pinched some. I looked at the wires and they appeared to be okay. I haven't tested with an ohm meter though.
The light went out on the dash and the radio hasn't cut out anymore. I guess the rear wire loom problem is a fix all even if the wires are not broken.
Wow, it sounds like that wiring loom is a nasty little booger. I have never even paid any attention to that area on either of my LS400s. Exactly where is this trouble area located? Right at the hinge?
Thanks for the photo of the exact spot! Wow, in that area, its no wonder there were issues. Looks like the wires could get pinched! Was this photo after you moved the wires around?
That is not factory. It doesn't look like mine did anyway and I know mine was factory. The tie wrap and sloppy electrical tape give it away.
