Bought 1990 LS400
I pass that place all the time when I am traveling through Ohio, on I-76. 2 days to ship or maybe a 1 hour drive to Anne Arundel County in MD,,,hmmmm,,,,,,where are my keys? LOL!!!!
Go To Amsoil.com And You Can Buy The Oil And Have It Sent To Your House Anywhere In The Usa. I Haven't Heard Anything About Mobil Be Changed Only They Have Added The 15,000 Mile Oil Call Mobil One Extended Which I Use And My Lexus And It Runs Fine At 193,000 Miles.you Can Also Get A Small Pump At Any Auto Shop And Pump Out The Power Steering About 6 Time To Get All The Old Oil Out Use Dexron 3 Or Dexron 5 Trans Fluid, Don't For Get The Rearend Oil It Needs Also To Be Changed About Every 30,000 Miles. And Change The Trans Oil Till It's Bright Red. You Are Driving The Worlds Best Car Good Luck !!!!
Um...why reply redundantly... four times?
I know you can buy it from Amsoil...
I posted that fact before you even did.
Anyway, I know what fluids I'm going to change, and have a list set up. Hopefully the car has been maintained well in the past.
Thanks for the swift response. I was wondering about the timing belt. I did some research and had also found that the engine is a non-interference engine, so that's obviously a good thing, maintenance-wise.
I'll go ahead and change it anyway, as there's no way I can tell how old it actually is. I sorta forgot to ask the owner about it, which I see as a stupid mistake on my part.
Funny thing about the car is that I keep finding new controls and buttons around the place. I had a '98 Volvo S70 that had no where near the complexity of the LS400!
As for oil, what kind or brand is recommended? Should I keep following the manual or is there a better synthetic out there. I do know it's been running on regular oil...so will the gaskets start leaking if I put in synthetic at 130k miles. This is after considering the fact that I screwed up my Volvo by changing to synthetic at 100k miles. A million places started to leak oil.
You can take off the distributor cover on the drivers side of the engine (its not blocked by the intake), its very easy, just four 10mm bolts, and you can visually inspect the timing belt. I wouldn't worry about the belt though, I never actually seen a timing belt break, usually the water pump goes first, and in order to replace it timing belt must be removed, so this is when most people replace timing belt. So you can just wait until your water pump goes, of if you still insist on replacing the timing belt, make sure you get the water pump as well, along with crank/cam seals, new o-ring for bypass pipe and water inlet housing, as well as new idler pulleys and tensioner.
Your car is 18 years old now, and it probably already has some minor leaks. I don't think it would be a good idea to switch to synthetic now.
Outside of that, I actually didn't think of replacing any gaskets and pulleys. I'm sure I need a new pulley as one is not exactly turning on track, but instead wobbling a little.
The oil is my biggest concern. Switch to synthetic or not bother.
I'm more concerned about the car's longevity, so will synthetic be useless at this stage?
I haven't found any leaks at all of any kind, except the suspicious power steering but I can't find the leak, yet sense it's there...(there are air bubbles in the fluid).
landon1850
13
10-13-16 01:59 PM
BeLSNow111
30
10-21-15 07:58 AM
motorscape
07-12-12 06:07 PM
jakemt
21
11-27-06 09:04 AM
