What do i need to do to lower my ls400?
Old 01-05-08, 08:32 PM
vitico160
vitico160's Avatar
Question What do i need to do to lower my ls400?
Hey, I have a 1990 LS400 and i whant to lowerit and i wanted to now what to i have to buy to do it? i'm affraid that if a lowerit it will eat the tires from inside, so a whanet to now if you can give me some advice!
Old 01-05-08, 09:14 PM
LiCelsior
Retired
LiCelsior's Avatar
good tip in advance is to search first but since ur new, ill cut u some slack.
im currently running KYB shocks with H&R sport springs which drop 1inch all around...there are also tanabe DF210 springs that will drop the car 2-2 1/2 inch all around. there are also JIC-Magic FLT-A2 coilovers that will give u as much flexibility for raising or lowering your car but they cost a pretty penny....if u have air suspension u can also just get a air control module.
Old 01-05-08, 09:21 PM
trukn1
NELOC Mod
trukn1's Avatar
well first,,how low do you want to go?? Are you going to run rims?? and if so how big??? These are all questions you need to consider.
Having a first gen LS, unfortunately, you will not have many options. They are as follows.
1. Cheapest/most common- lowering springs (H&R,Eibach, Tanabe) with new shocks. average $60-800
2. More expensive - coilovers. Gona be hard to find for our first gens and are very pricey. JIC and 1 other brand are the only ones I can think of.
average- $1400-1800
3. Very expensive - UAS (Universal Air Suspension). aftermarket product which will get you as low as you want to go. Very expensive if you are not a DIY'er. average- $2000 (unless you fab a setup yourself)
oh and welcome to the club. Look under the search and advanced search feature here to find alot of answers to possible questions using key words. Trust me,, searching really is a valuable source. Then if you cant find the info,, toss it out there in open forum.
Old 01-05-08, 10:52 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
Rear: go and buy several hundred pounds of freeweights and put them in the trunk, this should lower the car by 1-2inches, if more of a drop is desired, simply add more weights (up to 800lbs) and enjoy
Front: strap 2-3 dead* animals (cows, horses, etc-same size) to your hood and enjoy, same amount of drop as front, add or decrease animals to achieve desired look.
*Live animals may be used but maintainance will be much more difficult.
Old 01-05-08, 11:22 PM
LS4forME
LS4forME's Avatar
PureDrifter's Post = LOL
Old 01-06-08, 12:46 PM
Dutch
Dutch's Avatar
this is how i have my car lowered, i use the dead animals for the front. just a note though, make sure you have car freshener so the smell isnt too overwhelming
Old 01-06-08, 02:55 PM
Sportznuts
Sportznuts's Avatar
I usually just have my Aunt Mildred sit in the back seat and that usually does the job.
P.S. I don't really have an Aunt Mildred but if I did........
Old 01-07-08, 01:42 AM
TJW98LS
TJW98LS's Avatar
Are you drunk?
Personally, I'd tie down a whale to the top of the roof to achieve an equal balance of drop...and it would drop you as far as airbags!
Old 01-07-08, 05:47 AM
19psi
19psi's Avatar
how low do you need to go? what look are you after? a modest drop won't eat your tires if you get an alignment afterwards.
Old 01-07-08, 07:52 AM
Suneet
Suneet's Avatar
I use heavy stereo equipment
Old 01-07-08, 08:25 AM
KevinfrmSD
KevinfrmSD's Avatar
Just go air.
RickyDavis
20
03-22-13 09:00 PM
harvi666
08-29-12 12:16 PM
my98ls400
01-05-09 11:08 AM
Koolaid338
06-24-07 04:45 PM
ES4sale
10-01-04 06:43 PM
Quick Reply: What do i need to do to lower my ls400?
