95 LS warning light..What does it mean?
I have a 95 LS with 97k and I had an exhaust gasket and bolts repaired at the Y pipe the other day. My wife took the car to work about 20 miles away, and then on her way home a warning light came on. The light is a circle with three "dashes" going around the circle on each side. It went out for a few days but then came back on and has been on ever since. I assume anti-lock brakes, but not sure. Did a search but found nothing. Any ideas?
Yes unfortunately it is a sensor - easy to repair but pricey from the dealer. I have seen the sensors available on the internet for $65. i believe there are two total - one on the rear and one on the front. My light was on for 3 months before I finally broke down and repaired it. It is a quick job.
I guess I'll start by having my brakes checked at a local shop. The light does not say ABS anywhere, and my wife told me that all the manual says about the light is "see your Lexus dealer"![Yikes!](https://www.clublexus.com/forums/images/smilies/yikes.gif)
I'm giving my wife some credit here, but maybe I should check it out just to be sure.
You know how that goes![Wild](https://www.clublexus.com/forums/images/smilies/wild.gif)
I'll let you know what happens. THANKS
Thats the light that shows up when your pads are worn. Don't just replace the sensor, because the light came up for a reason...your brakes NEED to be replaced, or at least the pads.
