do you know where the parking brake wire is?
I am trying to locate the parking brake wire, and maybe even the color of the wire as well. I have been searching Google, here, and even lexusownersclub to no avail.
thanks!
thanks!
haha I have no clue... I need to "hack" into this wire to make the car think the e-brake is engaged..... but I have not a clue where this wire is. You might be correct, but I would have no way of knowing! haha
thanks for your quick response
like puredrifter said if its for a dvd/navi. you would use this
http://www.radioshack.com/search/ind...igkw=SPST&sr=1
put it inbetween. than it works
. thats what i had to do for mine
hmm... ok...
The particular dvd player I got can't just be grounded to play dvds while on the move... before you play the video, you need to do what is called "the parking brake squence (engage brake, dis" ", engage, dis" "). I thought I would hook it up to my e-brake wire, and only push the e-brake in one click, to where the wire would think its engaged, but the brakes are not actually engaged.
Is this the wrong way to go about this?
i think your best shot is the SPST switch. it will engage disengage engage disengage. since your able to flip it multiply times. usually all you would have to do is ground that particular wire. my friend has a 2007 model clarion. i have the pioneer avh-p5700dvd. can you clarify what kind of deck you might have.
Do you guys know where the ebrake wire is, or has pretty much everyone just grounded it out?? I ask now more out of curiosity than anything, because I looked for so long online at and the actual assembly. Its annoying the crap out of me!! Haha
I am going to run to the nearest radioshack/pepboys tomorrow to get at that switch!
okay here it goes i did some research on the particular dvd deck you have. doing the switch way should work.
http://forum.ecoustics.com/bbs/messages/4/278797.html
second link for more info
http://www.fixya.com/support/t126992...witch_in_order
if you go to that link it literally shows you how to disable it to the max lol. happy working on it.
if you do the full bypass you might be dead meat if a cop sees. thats why i recommend the switch. you can turn it off and on :]
Haha thanks brother...I appreciate the info!!
1GStoEnvy
05-27-08 12:14 PM
chromer699
14
01-27-05 01:39 PM
