Strange Braking/electrical Issue just started today!
Old 01-14-08, 06:58 AM
93LSexy
93LSexy's Avatar
Exclamation Strange Braking/electrical Issue just started today!
Hey guys,
my 93 LS has been running beautifully since I got it. this morning it started doing something very strange. I have a long commute everyday to and back from work about 50 miles each way. by the mid of the trip this morning, when i hit the brake, the radio when off and the "abs & trac" light came on on the dash. then everything went back to normal immediatly. then about 5 minutes later, i hit the brake, it did it again. there after i started to notice when I hit the brake, the dash lights will dim down. then...about 10 minutes later, i hit the brake again, ALL the lights on the dash and instrument went off including the radio and then went back on. WHAT IN GOING ON??
it doesnt do it every time i hit the brake...but this driving me crazy! i'm afraind next time i hit the brake, the car will shut off!!
Please help!
thanks.
Old 01-14-08, 07:04 AM
sbguyy
sbguyy's Avatar
Originally Posted by 93LSexy
Hey guys,
Please help!
thanks.
I had this happen to me! I found out that it it was a bad battery!
Old 01-14-08, 07:10 AM
93LSexy
93LSexy's Avatar
thank god! i thought i have to tare the whole car apart to figure out the short somewhere. Why and how is the battery causing this??
Old 01-14-08, 08:33 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
A-search
B-check trunk hinge wiring harness.
Old 01-14-08, 09:00 AM
dashan
dashan's Avatar
A bad battery connection also causes those problems.
Old 01-14-08, 10:03 AM
93LSexy
93LSexy's Avatar
Originally Posted by PureDrifter
A-search
Please be a little bit more specific on B? which and where abouts is the harness that I should be looking for?
Thanks!
Old 01-14-08, 10:04 AM
93LSexy
93LSexy's Avatar
I will clean and check the connection tonight and see if that fixes the problem. it's strange that it just started out of no where and only does it once awhile.
Old 01-14-08, 10:23 AM
19psi
19psi's Avatar
either bad connections at battery or trunk hinge harness fault. the harness is on the left side of hte trunk tied to the hinge. take the covering off it and inspect all the wires. one of them is probably broken.
Old 01-14-08, 10:51 AM
93LSexy
93LSexy's Avatar
thanks to all. this site is awesome! I will check the wiring harness and terminal tonight to see if I can fix this glitch.
kdecluette
06-28-18 08:17 AM
crenfro
Performance & Maintenance
03-06-13 09:57 PM
Dsc430
11-24-07 04:59 AM
essee300
Wheels, Tires & Brakes Forum
10-06-03 05:38 PM
anthracitetarga
SC- 1st Gen (1992-2000)
04-23-01 11:05 PM
Quick Reply: Strange Braking/electrical Issue just started today!
