Fuel Guage Problems.... Help!!
well i would prefer new, that way i dont have to worry about it, i will buy it from the link posted, just want to make sure thats the right one and will work. Theres alot of other criteria like series number and terminal types and all that other stuff.
Its inexpensive enough to buy new and not have to worry.
I have the same problem. Anyone happen to have pictures or a simple description (or perhaps a link) on how a layman can fix this problem? At the moment I don't know where on the cluster to look, etc. I do have soldering gun, etc.. and I have soldered before. I am guess I find the capacitor, snip it off? Then solder new one in its place, and that is the skinny of it?
Pictures would be great, (IE: If someone has a cluster out of the car, could you take a few snaps and circle the area of the capacitor using MSpaint or something) --
-- If not any description or link to a how-to would be great.
If no how-to's are available, I will create a DIY article with extensive pictures and post on this forum when I do it myself.
*Edit* -- When I get to this page:
http://www.newark.com/jsp/search/bro...&Ntt=c142&Ntx=
Searching for the C142 cap -- I am unsure of what 'specifications to mark' to obtain the correct cap?
Thanks,
Thanks,
Don't get to hung up on the exact voltage. Use a Capacitor with at least as high a voltage rating as the one you are replacing. C142 is a 4.7uF with a 25V rating....this is a tough one to find. A 4.7uF 35V is available at most supply houses and Radio Shack. That is what I used and it works fine. You could even use 35V rated caps for the 16V C212 for those with a dash light problem.
Tripfly
Tripfly
Tripfly
Tripfly
If I am looking through old electronic equipment. How will the capacitor be labeled? So I know exactly what to look for?
Is the cap black generally?
Thanks,
I am not sure I would be looking for caps from old equipment because heat is the enemy of capacitors and the dielectric will breakdown over time. You would probably be better of using 85 degree caps from Radio Shack. (Remember 85 degree C is something like 180 degree F)
Good luck
Trip
Thanks,
Thanks,
http://www.lexls.com/tutorials/elect...ntcluster.html
CIRCUT BOARD REMOVAL AND CHANGING PART
http://us.lexusownersclub.com/forums...showtopic=5822
Tripfly
Tripfly
Mojoman!
Thank you so much. That is exactly what I have been asking.. Makes me feel a little bit like a fool because the information is on this board somewhere obviously
-- But, this board is now huge, so it takes a bit of digging. I truly appreciate you linking exactly what I needed to do this repair.
I have but one more question now:
While I have the board out, I might as well replace all the caps, I even saw a transistor mentioned that often goes out.
I can't imagine the total price being more than 10 dollars if I bought ever cap/trans on the circuit board that is likely to go out.
With that in mind:
Could you guys list for me all the Capacitors and any transistors (even if it just that one mentioned in the link above about the flickering lights) -- that I would need in advance?
IE:
C142 - 25v 4.7uf
C212 - XXv XXuf
and so on? So I can go ahead and buy all the parts.. and I am going to bring this over to my grand father who worked for Nasa as an electrical engineer. He is in his 70's so I might have to do some of the steady work, but I've never brought him something he couldn't figure out how to fix, and changing caps and such out should be right up his ally, especially with that small guide telling approximately what to do.
So, I'm just missing what all parts to buy -- You don't have to link the parts to me (though that would exceptional) -- I can go to radioshack and ask for all parts you list.. but I would highly appreciate it if any of you can just rattle off the Caps/trans and their ratings for a 1994 LS 400 (Of course only the ones that are likely to go bad.. which might be all of them for all I know).
Again thank you!
With that in mind:
IE:
C142 - 25v 4.7uf
C212 - XXv XXuf
Again thank you!
Thermactor
17
11-06-11 11:14 PM
chrisngo
12-01-03 07:01 PM
