im in ur doorz (a problem with my driver's side power window '90)
Old 01-26-08, 09:37 AM
zokustyle
zokustyle's Avatar
Default im in ur doorz (a problem with my driver's side power window '90)
makin ur windowz not work properly.
i've been having a problem with my driver's side power window. it'll go down fine. but usually won't roll back up. i can hold the button up forever and it won't. luckily for me, it's been stuck down while raining at night, or on cold days.
i'm thinking the motor is dead. would a motor replacement cure all of this, or is there something more simple i've overlooked?
Old 01-26-08, 11:16 AM
Bali26
Bali26's Avatar
Yeah, the switch !
Old 01-26-08, 12:47 PM
shonn
shonn's Avatar
yea my 91 is having trouble with the passenger side window and the rear passenger window. Could it be just the main switch in the drivers door? I really hope it's just that.
Old 01-26-08, 03:55 PM
208Soarer
208Soarer's Avatar
I just replaced the master switch on mine. Mine would go down just fine, then you would have to pray to Jesus you could get it back up. Sound really similar to your problem, I replaced the switch with one from a ES250 90 I believe, I had to use the good base/connector from the ES with my Black switch cover and woodgrain. Works like a CHAMP, cost $20 at the local salvage yard, and 15 mins of time
Old 01-26-08, 10:12 PM
shonn
shonn's Avatar
wow so that's ALL it is? how crazy is that? lol
Old 01-26-08, 10:14 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
yea, almost all old toyotas ive had/worked on have had at least ONE window switch die.
sometimes u can fix it by cleaning the contacts but a lot of switches arent serviceable.
Old 01-27-08, 03:05 AM
absolut
absolut's Avatar
yep, the same thing happened to my '92. I swapped the master control switch from my '91 and everything worked fine after.
Old 01-27-08, 10:17 AM
skperformance
skperformance's Avatar
replace the switch AND lube the rails ,
Old 01-27-08, 07:08 PM
HaryGahtoe
HaryGahtoe's Avatar
Anybody got a good working spare master switch for this guy?
Old 01-27-08, 10:28 PM
shonn
shonn's Avatar
And me too? lol
Old 01-28-08, 11:04 AM
fisher9720
fisher9720's Avatar
THis happened to me on my 91.
BUt it wasn't the switch but rather the window motor.. I originally thought it was a window regulator..I assumed it was the wire kind with the pulleys adn such, but no case.. I took apart and this regulator is really simple, using a few springs and one main arm..
I could roll down, it was slow, but wouldn't go up.. It would make a popping sound about every 3 inches or so...
It was the motor... NEw one was $330 from Dealer.. Just bought one on ebay from a junkyard for $40 and put it in, worked fine.. So in my case something inside the motor broke, I would guess.. So if you window is going down smooth and no clicking or anything, probably the switch, if you hear any abnormal noise, get a motor!
atlantis43
Maintenance
03-14-12 10:55 AM
rgarabello
Maintenance
10-26-11 10:20 AM
PanicUnit
Maintenance
08-20-10 08:23 AM
windom619
05-08-08 05:05 PM
jpvarghese
SC- 1st Gen (1992-2000)
12-18-06 10:26 AM
Quick Reply: im in ur doorz (a problem with my driver's side power window '90)
