coolant amount
coolant amount
what if someone had put too much coolant in the radiator, what happens to the coolant, does it just drain out, i have a 91 ls400
thanks poicow
thanks poicow
If the engine block, radiator, and coolant reservoir were all filled completely, some of the coolant would be lost when the car reached operating temperature and was then shut down. In theory, the overflow should come out of the pressure cap on the coolant recovery reservoir. Given the poorly designed coolant overflow reservoir, what would likely happen is a coolant leak at the top of the tank where the coolant level sensor is attached.
