My Grill Rattles....Does Yours?
Old 02-10-08, 09:23 PM
eddievegas
eddievegas's Avatar
Default My Grill Rattles....Does Yours?
Hello All,
Actually I'm guessing it does, I just can't hear it. I noticed when I had the hood open the other day that my grill on my '98 LS 400 is not securely attached in the hood. It feels like it moves about 1/8 to 1/4 inch (forward and back versus side to side) when when I move it with my hand. I can't see how it is secured.
Does anybody know how the grill is secured? Also, the next time you walk by your LS 400, please give give it a pull or push and let me know if it moves. Maybe they all do this, but I'd be surprised given the fit and finish on a Lexus.
Thank you.
Eddie
Old 02-10-08, 09:27 PM
LiCelsior
Retired
LiCelsior's Avatar
tighten it down maybe?
Old 02-10-08, 09:38 PM
jcrome04
jcrome04's Avatar
should be bolts underneath where the top of the grill meets the metal of the hood.
Thats where I removed it to install the billet grill on my 91. don't know if it's changed for 2nd gen.....I'd assume it's the same though.
Old 02-10-08, 09:57 PM
zokustyle
zokustyle's Avatar
nope, shouldn't be different.
something's either loose or broken.
Old 02-10-08, 11:15 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
yep, the grill is supposed to be basically screwed into the metal surround....
Old 02-12-08, 06:25 PM
eddievegas
eddievegas's Avatar
Thanks for everyone's comments. I tightened the nuts at each corner and it didn't help so something else is going on.
I'll figure it out over the next few days and post an update.
Eddie
Old 02-12-08, 06:59 PM
tbilisi79
tbilisi79's Avatar
I got the same problem. But I dont care about it much.
Old 02-12-08, 08:28 PM
Neofate
Neofate's Avatar
Super glue?
Nah, I'm sure you'll figure it out if you take it out and see exactly how everything is attached. Might be some portion of the grill itself that has become cracked/broken.
Hopefully not, and you'll just find the area to tighten it. Or just add an additional screw/bolt or two in some hidden areas to keep it tight.
Old 02-13-08, 05:42 AM
MadMax96
MadMax96's Avatar
I noticed my grille was a little loose when I was washing my car last summer - turns out one of the small screws was missing entirely.
I just dug through my can of miscellaneous screws and fasteners that I've collected over the years and voila! Problem solved.
Maybe you have more than one missing?
Old 02-13-08, 10:01 AM
TJW98LS
TJW98LS's Avatar
It shouldnt be moving like that. Open the hood and look at your bolts. They are 10MM bolts so, I would first tighten those up if you are not missing any. I would look for holes in the back of the grille as well. Smaller ones are screws and the bigger ones are the 10MM bolts.
Just for reference, what part of the grille moves? The whole part or just the inner grille?
Old 02-13-08, 12:03 PM
Alan D
Alan D's Avatar
Mine moves around too, I think I tried tightening the screws and it didn't make a difference. Guess I'll look at it again.
Old 02-13-08, 12:06 PM
McSwine
McSwine's Avatar
same here.luckily I can't hear it over my suspension knock.
Old 02-13-08, 12:26 PM
eddievegas
eddievegas's Avatar
There's a Lexus emblem in the center of a plastic grill with horizontal grates. That is the piece that moves.
I just tried tightening the Phillips head screws and that did not work. As I said, I tightened the 10mm bolts yesterday w/o success.
Anyway, I'll figure it out and post an update.
Thanks everyone.
Eddie
Old 02-13-08, 05:28 PM
TJW98LS
TJW98LS's Avatar
Could it be possible that the screws and bolts could be stripped do to wear? Seems like a few people are having the same problem.
Old 02-13-08, 07:04 PM
Neofate
Neofate's Avatar
Good call TJ, but from Eddie's description I think he has tightened them and they 'felt tight'. If stripped they would continue turning and turning (and you would even be able to have a little vertical play depending on how much the threading was stripped)
I think those bolts do hold the grill in place, but there are more , perhaps less obvious, screw/bolts to be found to remedy the situation.
If it were me I would examine it really well,.. and if I saw nothing else obvious to work with I would do a quick fabrication job of my own screw/bolt in recessed areas of the grill. This should be a rather simple project to get a plastic piece tight on the car, even if you can't find the 'original' method of tightening.
It could be those two bolts are responsible for the tightness, but something else in the framing/plastic has malfunctioned and you will have to do something as I suggested to tighten it all up snug.
I don't know how loose it is, but be sure you get around to it sooner than later so you don't have replace it
Do inform us of what you managed to figure out/do,.. as it just adds to the database of awesome information here.
Thanks,
CCJ22
04-27-11 12:51 PM
pass427
09-29-10 08:26 AM
GSJake
06-07-09 01:08 PM
tancuan82
01-04-02 11:25 AM
Quick Reply: My Grill Rattles....Does Yours?
