Stability Control ever save you?
In my situation I doubt you wouldve been able to squeeze out of the scenario without comming all the way around or slamming into a car...
The way my car was pointed, when the missle-beep came on I thought it was locking on to a parked car and getting ready to slam into it. It was insane though, I never had a car take over so quickly to the point where I was like, WTF just happened?
I was going around a turn onto a freeway on ramp and it was a little wet, needless to say, I was going to fast and the dash beeped and my rear end was sliding and as soon as the beep went off the DSP kicked in and made the necessary correction to keep me out of the bushes.
Every car on the road should have this system.
as soon as you feel it slip you should be off the gas countersteering, and applying light brake pressure
for some reason in the snow, i can drive a -1x* cambered car with 300HP sliding everywhere, and STILL have complete control, without any help from fancy traction or stability control.
i just think all these aids are slowly killing the true driver input of driving a car. Its meant for the people that cant differentiate a fully inflated tire from a half inflated while driving. or cant tell when timing is slightly off but the way it accelerates, along with a host of other things most people cannot FEEL, but instead rely on lights, and sounds to tell them.
why did you let it get that far?
Inflated tire - Solid feel and fll response
Half inflated - Sluggish feel and response...then the car pulls to the side with that tire...
All Tires half inflated - You pretty much bottom out your wheels on every bump, cornering is terrible, traction is loose, and your RPMs will be relitively higher due to the extra effort pushing the wheels.
Not too hard to understand.
^ Where did the heated seats come from? lol. Although it is strange that a '97 didn't come with TRAC, I thought it was standard?
So unless I'm mistaken, TRAC is just another butterfly valve in the throttle body that modulates your throttle right. And VSC controls the brakes to ensure each wheel is spinning at the same speed. Whenever traction is lost in the '99 LS, I can hear a strange "springy" (like boing), sound, so is it safe to assume that is the VSC working? Because it never beeps in that situation. But the beeping comes when you are losing traction hardcore...Is there another stability system that I'm not aware of? Or is the computer saying you are in some major trouble and thats why it is beeping? Seems to me like it is supposed to inspire some sort of panic lol.
