OverDrive Light Flashing
You mentioned "the light was gone" and "seems that the light is stuck lit"
You mentioned using an "extra" ECU which the light is no longer lit.
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
the mechanic was not sure of the problem they wanted to trace it and I had an extra ecu computer. The one that was in the car he said was in diagnostic mode or something and flashing the O/D. So as a test they swapped it out. they were not sure if it was wiring or the computer or something else. I want to fix original ecm that one and use it because it been has been refurbished.
When they put in my other ecm computer the O?D overdrive light was gone. if you put the original one back in the light will flash.
1, Did you disconnect the battery and waited at least a few minutes when you removed and installed the cluster?
2, Did you replace ECU capacitors?
I had wild bill replace ECU capacitors and then I removed the cluster later.
I might not have waited the 5 min. I had to adjust the steering wheel so the battery was reconnected at some point and then taken off again during the removal.
As is shown below, the cluster unit is always connected to the battery via 10A dome fuse and removing connectors should be done after the +B line becomes lower than 0.5V waiting at least a few minutes to avoid the damage to semiconductors. It would be the best to measure and confirm the voltage is low enough before removing connectors. The audio circuits and computer units have big electrolytic capacitors inside and they are still holding electrons some after the battery is disconnected and the voltage at the +B line goes down slowly. I hope that your cluster's semiconductors are not stressed by the remaining electrons.
![](https://cimg4.ibsrv.net/gimg/www.clublexus.com-vbulletin/389x514/screenshot_at_2021_11_16_14_29_09_b3ec5d0ac119eba44f363cc36b69b2340bf39abb.png)
Hello Yamae, Do you know Mr. Basch? I replaced ECU capacitors. What do you think what I can do to fix my problem?
It seems that changing the engine ecm did not make a difference the overdrive light is still flashing.They claimed it was fixed. The code might be 11. They did fix the air bag light problem. They cleared the code.
thefiveoh
Performance & Maintenance
01-27-10 11:09 AM
DroppedGS
GS - 1st Gen (1993-1997)
04-09-03 11:52 PM
