Help electrical issues.
Before I get bashed by the search ****'s I have done my search to no avail. I have a 90 ls 400 and since i bought the car a year ago I have had a few minor electrical issues. they are as follows:
1. No power mirrors (defrost works but cant adjust them)
2. No cigarette lighters ( they worked at first but about no they dont)
3. No seat heaters
4. Temp needle stays at the top of gauge. (not an over heating issue just a faulty gauge.
5. Keyless entry not working
Any help or links to where I might find information about how to address these issues would be great. I am at my wits end with these problems and I would love to fix them.
3. No seat heaters
3. No seat heaters
3. No seat heaters
This would all lead me to believe bad fuse(s). This should be fairly obvious, and if you haven't checked all those fuses then shame on you..
Other than that if fuses are good, you might want to pull them all out (of course only the applicable fuses, not ALL fuses in the car
If it is definitely not fuses, It is going to be some type of electrical problem (of course),.. that will need to be traced down. I can't help you here, but you might could search for wiring diagrams to your car and trace some of the wires yourself, and use a tracer/short detector and other misc tools (multimeter) to find the fault(s).
Here is a thread on seat heaters not working, maybe it will lead you in a proper direction:
https://www.clublexus.com/forums/sho...ight=bad+fuses
But to make it easier --
The gauge thread is:
https://www.clublexus.com/forums/ls-1st-and-2nd-gen-1990-2000/40025-instrument-cluster-circuit-board-is-bad-1000-bucks.html
and a 'speedometer needle' (I know its not the same, but they all work in a similar fashion) thread is here:
https://www.clublexus.com/forums/sho...d.php?t=225935
1) Do you have the 'remote' button switched off to the left of your steering wheel? There is a button that turns this function on and off.
If it is on,.. then it could be a part of the electrical (fuse) problem that has that part de-activated atm.
That is the most obvious.
2) The battery in your key,.. its old , no? have you tried replacing it? It isn't a hard job at all.
Lastly -- A good thread about disfunctional keyless entry is here:
https://www.clublexus.com/forums/sho...+entry+problem
Godspeed,
3. No seat heaters
3. No seat heaters
As far as your temp gauge, try replacing the temperature sender. It is located on the water inlet housing, you're going to have to remove your intake, passenger side engine cover, and passenger side ignition coil to reach it. But it's a little tricky when ordering the part, our cars have four temperature sensors. One is on the radiator for fan control, and three on the water inlet housing - one for ECU, one for cold start injector, and one that send the temperature to the gauge. It's probably a $20-30 part, but make sure you order the correct one.
Thanks for the info my bad on not letting you guys know that yes I have checked the fuses and none are blown. I wasn't looking for a quick answer just some links. Thanks again I will try these solutions and threads.
Both mirrors and both cigarette lighters are out as well?
I know worn out wires on the trunk hinge can cause all kinds of electrical problems, but mostly related to the tail and brake lights.
Oh, yeah, also as far as the remote entry, check that it's on - theres a button on your dashboard. If it is on, check the battery. Also, sometimes the ignition cylinder wears out, and even when you remove the key from the ignition, it still "thinks" the key is in the ignition, and wont let you use the remote entry. When you remove the key and open the door, does your car start making the beeping sounds? If it does, thats your problem.
